#351 | |
Liked 120 Times in 53 Posts
Greg I'm expanding the mud slinging to show all of you that every make has bogus parts that FIT into the house rules at NHRA. I don't agree wi it either, along with many other obviously wrong decisions. So which part is the worst offender, the latest and greatest? Last edited by 4406mopar; 08-03-2017 at 05:40 PM. |
#352 |
All this assumes the LD-340 is worth something. When we did a A-B-A swap/test vs. a OE 71 340 #2100 intake, it was worth a grand total of zero point zero.
#353 |
Liked 327 Times in 121 Posts
Back in the early 70s I did an A-B swap at Hampton Raceway between the stock 69 440 intake and an Edelbrock CH4B, the car ran identical to the hundredth. The engine was a bracket race 426 street wedge with a Holley 4779. I did a lot of flow work with a stock 2100 intake and was very impressed how much better it was than the AVS intake.
#354 | |
Liked 21 Times in 8 Posts
you can dance just loosen up your laces |
#355 | |
#356 |
Liked 346 Times in 126 Posts
that is not the point, how many other combos do not have any option? Billy and other people are being myopic by only wanting to look at one or two mopar manifolds and want to ignore other combos that get an updated block, and replacement carbs.
#357 | |
Liked 1,855 Times in 433 Posts
Imagine if you had the 340 combo you have a reason to babble Go back and sleeve your block and make some magic. If you half your energy into your 318. As you do in this thread you may get somewhere
james perrone 1290 STK |
#358 |
wow, did you actually read what i typed or did you just react?
#359 |
Liked 312 Times in 175 Posts
This thread is killing me. I don't know if I should start to build a Mopar Stocker or pack drag racing in all together.
#360 | |
Liked 7 Times in 4 Posts
I Guess next is going to be how hard it is to find a Good stock Q jet and let us bolt on Fuel injection. Maybe even a Aluminium D port head some day . I will let you know what the side by side comparison is on those cause it's probably Zero point Zero as well. No assuming here lol.
Bob Aceves, 746 E/SA A&M motorsports |
