Old 08-08-2017, 11:40 AM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: more thoughts about needle bearings
1.5" diameter. I can get on all my head bolts.
We have that spring on one of our engines and they have held up real good. The others have triple manleys or comps. I am thinking about changing the others to the Pac spring. My machine shop guy is a manley and comp dealer so that's why I have been using that spring.
Mike Pearson 2485 SS
Old 08-08-2017, 01:52 PM   #12
Hacksaw
Liked 312 Times in 175 Posts
The real beauty of that 1.5" spring is that the pocket in the head is smaller, helps you stay away from water.
Old 08-08-2017, 02:01 PM   #13
Mike Pearson
Yup that's why we did it. The 441 chevy head is thin in that area.
Old 08-08-2017, 03:46 PM   #14
Hacksaw
Back on op: Any other theories on needle bearing lifter failures?
Old 08-08-2017, 06:13 PM   #15
SSDiv6
Liked 1,604 Times in 583 Posts
Wrong material, bad manufacturing processes and bad quality.
Old 08-08-2017, 06:32 PM   #16
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Prep is important . The assembly grease that holds the needles in place during assembly , needs to be removed before they are run . I use clean mineral spirits and blow dry . It is important not to allow the rollers to spin when blow drying . I have seen some Technicians spin those parts up to untold rpm while trying to dry them . That is a good way to skid and fail the rollers . After drying , I soak the lifters in clean break-in oil , and spin the wheels by hand to try and drive the oil into the rollers . Seems to work , haven't had a failure yet !
Old 08-08-2017, 09:10 PM   #17
carl hinkson
Liked 18 Times in 10 Posts
I have seen problems with lifters do to excessive lifter bore clearance no one seems to measure lifters and lifter bores just buy them and dump them in LOL
I seen where they have seized in the bore because not enough clearance.
Like I have posted before i have pretty much have gone to all .904 roller lifters in most of my builds and alot of the blocks I prep are machined for .904 and no problems.
No blocks go out the door with out having lifters in hand and lifter bores are honed to fit the lifters.
Had a guy last week where I priced out a Dart Little-M block roller cam bearings, Dry sump ETC. had Comp lifters told him those are to small and would probably need to bush the bores back to standard. He told me they measured .842 my reply was never seen a set of Comp lifters to OEM size yet. He would not send the lifters so I passed on the job and he was pissed at me.
https://www.facebook.com/cncblocks.n...79?pnref=story
Here is a good video on different lifters and bore clearance
carl hinkson is offline   Reply With Quote
Old 08-10-2017, 12:16 AM   #18
Bruce Fulper
Liked 54 Times in 33 Posts
Originally Posted by carl hinkson View Post
I have had more problems with ISKY roller lifters only as far as sizing, Never been able to buy just one set always 2 sets and one build took 3 sets to get the sizing correct.
O A Diameter problem?
Bruce Fulper is offline   Reply With Quote
Old 08-10-2017, 01:17 AM   #19
carl hinkson
Sizing from low to high
Look over these threads
http://www.yellowbullet.com/forum/sh...t=lifter+bores
http://www.yellowbullet.com/forum/sh...1631930&page=5
