#11 | |
Ed Wright 4156 SS/JA |
#12 |
Liked 1,034 Times in 368 Posts
Me 2 .. And 2 seasons ... Burnt up the BS box 3 times( Points Drivers ) .. The Digital 7 box twice ... I had Andy Kronenbitter ( PK Racecars) re-wire the whole car, switch panel, shutoff switch...everything . In the process ,he found the problem ... Its probably fine as long as your on 12 volt system ..But he came up with a point.. " that is not legal" ... You would have hot wiring going up through car at all times ... No way to shut it off...
Jeff Niceswanger 3740 SS |
#13 |
The battery cut-off switch kills my engine too. Shuts off everything but the battery charger plugs Eastexas Racecars put in my rear fender. Everything else wired to the cut-off switch. Killed two FAST XFI ECUs and two MSD boxes before I pulled my head out.
#14 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
#15 |
Liked 4,377 Times in 502 Posts
Just wanted to revive this thread to see if anyone was willing to share a race car wiring schematic or know where I can find a good one. I am still fighting RF noise and possibly some grounding issues with my o2 sensors. The tach signal is still very erratic on the graph.
#16 | |
Liked 1,604 Times in 583 Posts
http://www.concatoracing.com/ |
#17 |
Liked 21 Times in 7 Posts
Do yourself a favor & set the system up with a floating ground.
The only things that should be connected to a chassis are 4-link bars & shocks, not wires. |
#18 | |
Instead of running the ECU, fuel pump, and fans through the toggle switch on the dash, I power them from GM fuel pump relays, turned on & off by the toggle on the dash. ECU has it's own roofer relay. I was seeing some voltage drop running all that thru the toggle switch. Power for the relays are double 10 ga wires directly from the batteries. May be over kill. Everything, including to the batteries ground to a stud on the back of a cylinder head.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 08-29-2017 at 02:55 PM. Reason: Still can't type. |
