Old 09-10-2017, 12:17 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Replace rocker arm bearing
Has anyone ever replaced a torrington bearing in a rocker arm. I have one rocker arm on shaft system that is bad. I was able to read number on side of bearing and ordered several sets for just in case. I'm looking for tips on pressing old bearing out and installing new one. I know I could probably sent back to scorpion or buy a new one, but they are being hit in the face with Irma and there's no idea when I would get it back. Thanks.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 09-10-2017, 03:07 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Replace rocker arm bearing
I made a stepped pin that I use with my arbor press . Support the rocker arm with a socket , and the step in the pin presses on the outer cage of the bearing . Press out the old one , and press the new one to the same dimension . I did this on a Jesel rocker which the edge of the cage had cracked . It worked well .
Old 09-10-2017, 06:24 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Freeze the bearing and heat the rocker with a heat gun and they push right in by hand. You can use a socket and the shaft to push the old one out. Done several this way.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 09-11-2017, 04:43 PM   #4
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
If you are pressing a bearing check if the bearing sides are convex or flat ( like the Jessel bearings bulge outward not flat). if you don't press with a driver with a similar contour, it gets crushed, binds the rollers, and eventually cracks the bearing case. Heating the rocker body and cooling the bearing works well with light oil and can get by using a flat surface to press.
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 09-11-2017, 08:57 PM   #5
Ed McLawhorn Jr.
Thanks everyone for the comments/tips.
Ed
Old 09-13-2017, 09:29 AM   #6
nhramnl
Liked 358 Times in 83 Posts
...or you could just order a new rocker arm from Jesel. I always carry a spare intake and exhaust rocker, and if one of the rockers on the engine fails, I install the spare and call Jesel the following Monday. That way, I never worry if my rebuilding skills are inadequate.
