Liked 882 Times in 236 Posts
After seeing the result of Lou Centelazzo's unfortunate crash this past weekend , Id' like to remind my S/SS friends about something I find on all too many cars I see in my shop.
Many cars ,regardless of the type of master cyl. do not have a push rod retainer or a positive brake pedal stop to prevent the pushrod from disengaging the master cyl. . Since many cars have had the brake light switch removed there is nothing to keep the pedal from disengaging the pushrod but a small rubber retainer . A small bracket with a stop bolt in place of the brake switch will prevent this ,just be sure to keep a small amount of clearance between the stop and pedal. Another method that works if you have the Mopar master cyl , which most cars have is the Jerry Bickel push rod retainer kit . This retainer is simple and will work on almost any application ,and it's only about $70 .
Liked 7,748 Times in 1,741 Posts
Very good point Tom. I brought this subject up more than a few times this weekend.
For anybody interested, I brought up how to make a positive stop in the "Under the Index for Under a Grand" thread.
Liked 3,182 Times in 973 Posts
Ken Etter's crash at Fontana years ago brought this issue to the forefront for a while...good thread to remind everyone.
Liked 55 Times in 29 Posts
I've been there, done that. It is beyond a scary situation. You don't think it can happen until it does.
Liked 175 Times in 78 Posts
Why isn't it mandatory like a seat belt or helmet?
It could be covered in the tech inspections. Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
I made a cradle that sits just under the pushrod that even if the rod tries to come out of the piston it keeps the pushrod lined up to go back in
Doug Blackley 1697 STK |
#7 | |
Liked 320 Times in 102 Posts
Tech inspection HA HA HA HA NHRA Tech management is trying to cut expenses, not to protect the well being of the membership...
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 09-12-2017 at 01:58 PM. |
Here's a stop I put on a early Mustang that's in the shop .
Like Billy said ,only a couple of bucks of bolts and stock.
Liked 276 Times in 27 Posts
Simple test you can do yourself.
Reach down and pull your brake pedal up toward you to see if it comes high enough to let the rod fall out of the master cylinder. |
Liked 2,727 Times in 961 Posts
I hope Lou is okay.
