Old 09-12-2017, 09:39 AM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default S/SS Brake safety
After seeing the result of Lou Centelazzo's unfortunate crash this past weekend , Id' like to remind my S/SS friends about something I find on all too many cars I see in my shop.
Many cars ,regardless of the type of master cyl. do not have a push rod retainer or a positive brake pedal stop to prevent the pushrod from disengaging the master cyl. .
Since many cars have had the brake light switch removed there is nothing to keep the pedal from disengaging the pushrod but a small rubber retainer .
A small bracket with a stop bolt in place of the brake switch will prevent this ,just be sure to keep a small amount of clearance between the stop and pedal.
Another method that works if you have the Mopar master cyl , which most cars have is the Jerry Bickel push rod retainer kit .
This retainer is simple and will work on almost any application ,and it's only about $70 .
Old 09-12-2017, 09:53 AM   #2
Billy Nees
Liked 7,779 Times in 1,742 Posts
Default Re: S/SS Brake safety
Very good point Tom. I brought this subject up more than a few times this weekend.
For anybody interested, I brought up how to make a positive stop in the "Under the Index for Under a Grand" thread.
Billy Nees 1188 STK, SS
Old 09-12-2017, 09:57 AM   #3
jmcarter
jmcarter's Avatar
Liked 3,192 Times in 975 Posts
Ken Etter's crash at Fontana years ago brought this issue to the forefront for a while...good thread to remind everyone.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-12-2017, 12:18 PM   #4
j gardiner
Liked 55 Times in 29 Posts
I've been there, done that. It is beyond a scary situation. You don't think it can happen until it does.
j gardiner is offline   Reply With Quote
Old 09-12-2017, 12:58 PM   #5
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Why isn't it mandatory like a seat belt or helmet?
It could be covered in the tech inspections.
Ron
Old 09-12-2017, 01:05 PM   #6
Doug Blackley
Doug Blackley's Avatar
I made a cradle that sits just under the pushrod that even if the rod tries to come out of the piston it keeps the pushrod lined up to go back in
Doug Blackley 1697 STK
Old 09-12-2017, 01:55 PM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Ron
Tech inspection HA HA HA HA
NHRA Tech management is trying to cut expenses, not to protect the well being of the membership...
Bob Mulry 7516 STK
A & M Motorsports
Old 09-12-2017, 02:47 PM   #8
Tom Goldman
Here's a stop I put on a early Mustang that's in the shop .
Like Billy said ,only a couple of bucks of bolts and stock.
ID:	42493   Click image for larger version
Old 09-12-2017, 03:42 PM   #9
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Simple test you can do yourself.
Reach down and pull your brake pedal up toward you to see if it comes high enough to let the rod fall out of the master cylinder.
Travis Miller is offline   Reply With Quote
Old 09-12-2017, 03:48 PM   #10
Frank Castros
I hope Lou is okay.
