#11 | |
Ed Wright 4156 SS/JA |
#12 | |
Liked 19 Times in 8 Posts
Joe Schweigert 751 SS |
#13 |
Thank you Joe!!
#14 |
Liked 33 Times in 16 Posts
The only problem I ever had with the PPP was operator error. You have to adjust the cable with the shifter in second gear...if careless it is easy to move the shifter handle from it's optimal position by snagging the cable end under the car. I now double check the shifter every time when swapping/replacing the transmission.
Rich Taylor I/SA - 321 |
#15 |
Liked 881 Times in 236 Posts
90%Of the S/SS cars I work on in my shop either have the Cheetah shifter or are getting one installed .
I drove a DragPak Challenger I built with PPP shifter and had trouble with shifting right thru second gear . Operator problem , Yes . My big clumsy hand kept hitting the trigger ! .....But I've never had that problem with any Cheetah equipped car I drove.
#16 |
I always check the cable adjustment when putting the eng & trans back in the car. Mine is shifted by air. So far it has been flawless.
#17 |
Liked 269 Times in 99 Posts
The Turbo Action shifter is great but not so good with manual shift reverse pattern valve body. Very easy to slip from 2nd to 3rd. Did it many times had enough.
Precision shifter is the best, a little spray now and then if it gets stiff. Once in low gear each shift is just hitting the handle with you palm nothing more. Don't keep your hand on or hold it, after each shift it needs to reset to be ready to hit it again on the next gear change. With any shifter you choose proper adjustment is required when installing any transmission just to avoid dumb stuff we all run in to anyway.
#18 |
Liked 133 Times in 76 Posts
On the maintenance side....I never would have believed how much the cable resistance was after years of no lube. Shifter worked but not like it should. I removed the cable and sprayed cable lube in it so it ran down to the bottom and it really freed it up. I tried one of those motorcycle cable lube tools but the cable is too thick. that would be the trick for in the car lube.
#19 |
Liked 1,583 Times in 582 Posts
When possible and if available, use a control cable that has a Teflon liner and lubrication will not be required.
Also, make sure the control cable is not exposed to excessive heat. Excessive heat will dry out the lubricant or deteriorate the cable. If the control cable does not have a Teflon liner, lubricate with a spray lube designed for open chains that contains Moly Disulfide. One great lubricant is ACF-50 Anti-Corrosion Lubricant. |
#20 |
Liked 7 Times in 5 Posts
We have a PPP shifter in our AMX and i was a little skeptical playing with it just sitting in the car but going down the track and actually using it, it works great. we ran a cheetah before that and simply changed because the red PPP matched the interior of the car better.
