Old 10-29-2017, 11:13 PM   #1
john billups
Default Qjet idle rich.
GM 1980 305 w/ stocker cam, 2-3 inch vac.
I cant get a good idle, it loads up and it falling over about 90 ft. out then pickup a sec. later.
The carb was built by a local SS racer a few years ago. It has the pri. rods removed.
I have to have the throttle open a lot of turns to keep it running.
The fuel is being pulled from the mains and the idle screws have little affect.
I have tried other Q jet carbs, even a new Jet stage 3.
I guess the question is, how do I get this to run right.
john billups is offline   Reply With Quote
Old 10-30-2017, 08:50 AM   #2
Nmbr1GMfan
Default Re: Qjet idle rich.
Fuel pressure?
Todd Greene
Old 10-30-2017, 09:38 AM   #3
john billups
Fuel pressure
Started at 7psi I how have it set at 3.5psi.
Float is at 1/4 " , have changed float and needle & seat.
Old 10-30-2017, 10:31 AM   #4
Hacksaw
Liked 310 Times in 174 Posts
Did this carb ever idle on your car? When you tried the other carbs did they work properly?
Old 10-30-2017, 11:02 AM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Did any carb ever idle on this engine??
Are the primary blades drilled??
2 or 3 inches of vacuum is nothing??
You might have engine problems and not carb problems..
Such as vacuum leaks, cam timing, damaged valves or too many to list..
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 10-30-2017, 12:15 PM   #6
john billups
Carb worked on bracket 350. but w/ south a year later. Have rebuilt ,cleaned and blow it out. but has no
I have tried 3 other carbs on the 305.
problem on 3 different motors, all low vac motors.
smoked all the motors, no leaks, leak down good. plates drilled.
the motor will run with a Holley.
put a Jet 3 on this motor and still the same.
Old 10-30-2017, 02:27 PM   #7
kansas stocker
Liked 249 Times in 48 Posts
Are you sure you have the right gasket between the carburetor and intake manifold?
kansas stocker is online now   Reply With Quote
Old 10-30-2017, 03:04 PM   #8
john billups
I have looked at the gaskets but, I maybe should look at that . thanks
Old 10-30-2017, 04:05 PM   #9
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yes to this...there is a base gasket out there that is the mirror opposite of what is needed. Will cause a huge vacuum leak for sure.
Rich Taylor
I/SA - 321
Old 10-30-2017, 11:16 PM   #10
richie 2
Liked 205 Times in 93 Posts
a huge vacum leak will cause it to be rich? I thought I would make it lean...
