#11 | |
Liked 136 Times in 49 Posts
#12 |
Liked 13 Times in 9 Posts
Looking at the dial-in on the window is even easier.
#13 |
So we would put our dial-in on the window before going to tech ?
Bob Schmalz 3199 Stock |
#14 |
Liked 31 Times in 6 Posts
What do the metric guys do?
Only one place to get a shield. Tom waters race car products. Doesn’t clear case braces. On a 69 nova, it requires cutting/modifying floor pan more than rules allow for stock eliminator just to get it to fit. Run a blanket instead? This ain’t tractor pulling. Bye bye 350, hello 6 banger. V/SA here I come. Ryan Walther Stock 315 |
#15 |
Liked 508 Times in 92 Posts
Instead of worrying about blankets and shields, put a standard trans in your cars and see what fun it is racing and shifting gears. With Jericho and Gforce transmissions, reliability is at it's best. The biggest problem is figuring out the clutch, it's cheaper then converter's because you buy one and work with it. Breakage is minimal these days and repeatability is pretty easy.
Just a suggestion. Casey Miles 248H Stock |
#16 |
Liked 6 Times in 4 Posts
#17 | |
Liked 105 Times in 26 Posts
#18 |
Elegal shift is done? Or the shifter can't be electric controlled? Air shifters were allowed in stock? Big rule change here that needs some elaboration.
#19 |
OMG.... how do you think they do tech at bracket races? Go through tech: "How fast do you run?" "10.50's" "OK, you need XYZ." This is NOT hard.
And YES, the tech guys already watch E.T.'s. A friend has always wanted to run a 9.99 just once with his Stocker, but doesn't have a full cage. He was specifically told there would be no grace period. One 9.99 and he was out of the event. Again, the idea that one car running 10.80's requires far more stringent safety standards than an identical car running 10.00 is ludicrous. It also creates a potentially massive problem with insurance. What happens when a 10-oh car wrecks with a roll bar, -1 suit, etc., and the insurance company says, "Why didn't this car and driver meet the same safety standards as this other car that's much slower, but requires a full cage, -5 suit, competition license, ad infinitum?"
Michael Beard - NHRA/IHRA 3216 S/SS Last edited by Michael Beard; 11-03-2017 at 09:46 AM. |
#20 |
Liked 27 Times in 14 Posts
Michael,
Some of the bracket races I've watched here lately doesn't appear to have any rules when it comes to safety....helmet mandatory, everything else is optional. It's not my style but it also doesn't directly impact me! If you want the simplest rule when it comes to safety....everyone should wear the same thing and have the same requirements. After all, your 10.50 car is running against 8.50 cars going 160+. Nick |
