#11 | |
Liked 431 Times in 224 Posts
S/ST 51 S/C 53 |
#12 |
Liked 3,221 Times in 980 Posts
Same as my experience and as it should be to eliminate out of date stickers being applied to another car, which an unscrupulous seller could then advertise as "certified, just needs re-certification" Suspect that in Dixon's case the tag was removed when they did the modification and then reapplied. Seems like just a silly oversight in which case NHRA over-reacted, which makes me wonder if there's not some animosity between Dixon and NHRA. In any case the car had never been submitted for tech at a NHRA event. What's next? NHRA start giving suspensions ala NFL for violating some 'personal conduct policy'?
#13 |
Liked 348 Times in 152 Posts
Ever try to remove and reapply an SFI sticker? Good luck. When you remove them, it shows "void" in the remains. Anything is possible, but I would be hard pressed to believe Dixon R&R'd an expired sticker, for any reason. I'd have to think it just wasn't removed when the mods to the chassis were done.
Phil Molski PMR Performance S/C 1623 |
#14 |
Liked 482 Times in 159 Posts
A slight touch off topic, however I was at a race a few years ago and a racer crashed hard into the wall. When his car was returned, to his pit area, a track official immediately came over and removed his cert. sticker. Is that a normal procedure ? Should add the cars front end was bent up pretty bad.
#15 |
Liked 451 Times in 77 Posts
Watch the video, He made test passes WITH a passenger
This is more than an expired sticker on a show car. This is a Top Fuel car with a passenger. Anyone can point me to the SFI spec for that? Maybe if there was no video of the car making passes I could see this being excessive, but he made test passes with a passenger and ran it at a NHRA and IHRA track. I surely hope NHRA doesn't jump on this bandwagon. National events are enough of a circuis already. I wanted to puke at the 2 seat S/C giving passengers an "experience". at the summernats a few years back. This is even worse..... |
#16 | |
Liked 262 Times in 74 Posts
The entire video is shot at Palm Beach which is an IHRA track. What happens at an IHRA track is none of NHRA's business. It made test passes at an NHRA track that is true. You don't see an indefinite ban being excessive? Banned for life for doing something different at another sanctioning bodies track? In the interview with Larry, NHRA was fully aware of what he was doing, and was excited about the idea. I'm wondering if it had something to due with the Traxxas on the side of the car.
Steve Polhill 3520 STOCK, COMP |
#17 |
Steve, how the driver cockpit ties into the passenger cockpit is definitely not standard construction. I would seriosly think it needed to be reviewed and approved by SFI and a cert issued. Dixon knew this as he had computer modeling done prior to any modifications. Also the wheelbase is obviously stretched beyond 300" as it was originally Bob Vandergriffs old Hadman car, modified by McKinney, not all brand new pipe.
As far as his lifetime suspension, I don't believe that will be upheld. Kiss and make up and swept under the rug. NHRA will want a piece of this $$$ Maybe NHRA saw the video of Larry making passes with a passenger at an IHRA track, also he was scolded by NHRA earlier this year for promoting an IHRA race on the side of his dragster, and lastly, now he has Traxxas plastered on the side of this car... $$$. Is Larry friends with Mike Dunn??? NHRA Brass worried Larry will take Traxxas and his circuis act to the other circuis?? Don't know and don't care. I go to the races to race, not put the show on |
#18 |
Surprised this thread hasn't been moved to The Lounge
#19 |
Liked 920 Times in 259 Posts
Somewhere in one of the interviews or stories, I believe it was stated that, at this time, LD's insurance company mandated the car not go further than 330' under power with a rider in it. I suppose if someone wants to pony up 10K for a 2.3 second ride, Larry would be happy to take his money. No reason he can't run it. He just can't show up at an NHRA facility.
#20 | |
Liked 274 Times in 143 Posts
