Old 11-29-2017, 09:09 PM   #1
DDT
Thumbs up No drive by wire for 2018 and beyond.
Effective 2-08-18 Lucas Oil Winternationals. All drive by wire cars in stock and super stock must have positive cable operated throttle. This is to address possibility of traction control and down track timers.
DDT is offline   Reply With Quote
Old 11-29-2017, 09:17 PM   #2
Charley Downing
Liked 633 Times in 88 Posts
Default Re: No drive by wire for 2018 and beyond.
Lol
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 11-29-2017, 09:40 PM   #3
Crew Chief
Liked 10 Times in 6 Posts
Okay I'll bite. Where is this rule change stated?
Crew Chief is offline   Reply With Quote
Old 11-29-2017, 10:16 PM   #4
Frito
Frito's Avatar
Liked 119 Times in 40 Posts
Hum
Old 11-29-2017, 11:29 PM   #5
Jason
Liked 6 Times in 4 Posts
A rheostat on the accelerator pedal sends a signal by wire to the computer which in turn sends the command by wire to a rheostat on the throttle body and the throttle blades are opened. A delay box could be installed in the drive by wire system along with the other items.
Jason is offline   Reply With Quote
Old 11-30-2017, 12:15 PM   #6
DonatoEng
Liked 8 Times in 5 Posts
Would you want the person in the other lane calibrating their own throttle ?
That could be very interesting and scary
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 11-30-2017, 01:31 PM   #7
Todd Hoven
Guest
Posts: n/a
When is this coming out officially?
Old 11-30-2017, 01:58 PM   #8
btrc
Liked 84 Times in 42 Posts
I checked with my Division tech director and he said he hasn't heard this discussed.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 12-01-2017, 10:22 PM   #9
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
As if someone that knows how to program a DBW ecu to control throttle for traction control, can't control timing for traction control. Good try.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-02-2017, 03:39 AM   #10
RULER
Liked 58 Times in 18 Posts
Exclamation Re: No drive by wire for 2018 and beyond.
Hey, the LS1 guys had to change to mechanical throttle linkage years ago, so this only makes sense. It would be very easy to add down track info with the current drive by wire systems. It seems that would make dialing a lot easier if you use that type of system, plus a whole lot easier to tech......
RULER is offline   Reply With Quote
