Old 12-20-2017, 10:01 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Nhra no bigger than stock cam journals
http://www.nhraracer.com/content/gen...416&zoneid=132 So does this mean next year they will be checking for these big 55 and 60 mm cam journals.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 12-20-2017, 10:28 PM   #2
Default Re: Nhra no bigger than stock cam journals
Probably not.
Old 12-20-2017, 10:31 PM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
Check out this older thread, specifically post #23:
http://classracer.com/classforum/sho...nal+cam&page=3
"That'll never work....."
Old 12-21-2017, 08:34 PM   #4
MR DERBY CITY
Liked 8,006 Times in 1,526 Posts
This didn't last long, it has been removed from the site.......
Old 12-21-2017, 08:51 PM   #5
PJ305
Liked 5 Times in 4 Posts
Yeah Mr Derby City, NHRA must have figured 95% of their stocker fields would not be in compliance!...lol
PJ305 is offline   Reply With Quote
Old 12-21-2017, 10:00 PM   #6
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
In 2010 Pat Cvengros wrote: The cam shaft may be of the larger journal design. Must use babbitt type cam bearings. Non-roller design.
Based on the above letter, you would think it would be permissible to run a big base circle cam. When considering all the changes to stock NHRA has made today with stocker heads, why would NHRA enforce a stock base circle cam. Pat Cvengros caused plenty of people to utilize the larger base circle cam which I believe would be very costly. A clarification needs to be made so racers know which way to go. The other question is how much could the big base circle cam help. It may not help at all!
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 12-21-2017, 10:29 PM   #7
Jason
Liked 6 Times in 4 Posts
Originally Posted by John Duzac View Post
.The other question is how much could the big base circle cam help. It may not help at all!
But it sure would be an expensive way to find out.
Jason is offline   Reply With Quote
Old 12-22-2017, 12:03 PM   #8
Well, it was pretty stupid to rescind approval, long after the fact, of a relatively expensive modification to a pretty expensive part.
Further, given the other absurd rules for Stock valvetrain, allowing those cam cores helped re-level the playing field that was thrown way out by the other rules.
I'm not necessarily in favor of ANY of those rules, but if you're going to allow some to gain an advantage by opening some rules, you create an artificial advantage. And that's the problem with continually loosening the rules.
Old 12-22-2017, 12:24 PM   #9
Bobby Lundholm
Liked 127 Times in 49 Posts
delete
Bobby Lundholm 3516 G/SA
Bobby Lundholm is offline   Reply With Quote
Old 12-22-2017, 03:45 PM   #10
west coast
Liked 223 Times in 73 Posts
The reminder on NHRA for this rule also included larger diameter lifters, which i believe there are more of those then large journal camshafts. Either way there are a lot of blocks out there that would be not usable in stock anymore.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
