#11 |
Liked 4 Times in 3 Posts
Guys you are missing the point here.
Aftermarket heads are already accepted with a HP penalty. There is talk that they will become "replacement" heads and this result will eliminate the different factors of OEM vs. Aftermarket heads for the combos that currently have them. Trying to find out "if" this does go through, what will happen to the two hp factors that are currently different? |
#12 |
Liked 783 Times in 195 Posts
Conceptually, when you place a different hp factor on an engine because of the use of replacement heads (aftermarket or OEM), you have essentially created a new engine for the books. The problem is the way that classification is calculated since it uses a weight break of one rating and then the weight of the new hp factor. Eliminating the differential of ratings will simplify the calculation for the guys in the field, which is always a good thing since it helps eliminate confusion and mistakes.
#13 |
Liked 12 Times in 6 Posts
So does this mean that if a combination has been factored 20 HP now its gonna go back to the OG HP rating??
Example 396 Iron head is 375/385 396 Alum head is rated at 405HP Both heads go back to 375? |
#14 |
Liked 1,439 Times in 301 Posts
It makes sense to me that there would not be a penalty in superstock. heads can be modified extensively. Stockers should keep the penalty for the aftermarket heads. My opinion anyway.
James Schaechter 3163 STK |
#15 |
Liked 163 Times in 53 Posts
5hp off only for aftermarket head.....
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#16 |
Liked 293 Times in 65 Posts
Boy, I didn't see that coming...aftermarket heads for SBC in Stock. With a 5hp penalty.
NHRA Tech Department makes updates/corrections to the Stock Car Classification Guide Jan. 1, 2018 The NHRA Technical Department recently made changes to the Class Guide. Buick 98-99 added missing pages to website Chev 62-79 added SBC replacement heads for Stock Chev 2015 Camaro 376 365 corrected shipping weight Stk/SS Chev 1969 Corvette 350 300 separated auto/man transmission Ford 2010 330 500 added Stock weight breaks Ford 2012 330 510 added Stock weight breaks Plym 1968 Barracuda 426 425/505 separated from non SS/AH |
#17 | |
Liked 5 Times in 4 Posts
#18 | ||
Liked 13 Times in 9 Posts
#19 |
Liked 3,205 Times in 977 Posts
Looks like Dwight is going to be busy!
#20 |
Liked 456 Times in 148 Posts
Does Edelbrock then make a SBC head with intake runners 161-165 CC's? Edelbrock is the only approved head? All I have seen is 180 CC and up.
Steve Teeter STK 6380. |
