Old 12-22-2017, 01:20 PM   #31
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Default Re: Aftermarket/Replacement Cylinder Head Rule Change
Originally Posted by M Brand 505B View Post
The Aftermarket head has to retain the same specs as the head it's replacing.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Last edited by jmcarter; 12-22-2017 at 01:23 PM. Reason: never mind; will leave it to the guy who does my heads
Old 12-22-2017, 01:25 PM   #32
HR9121
HR9121's Avatar
Junior Super Stock
James Williamson
W200 J/SA. SS/JA
Old 12-22-2017, 01:29 PM   #33
PJ305
Liked 5 Times in 4 Posts
Originally Posted by Bob Mulry View Post
I think that we are missing the point on these replacement heads...
Runner volume is just one way to compare castings...
With the new replacement castings I would like to know what the flow numbers are from each head..
Just because the volumes are the same it has nothing to do with air flow or the horsepower that they are capable of making..
It looks like another can of worms just got opened for Stock...
Just sayin'
I agree with Bob, no need for all the choices. You know the flow figures will be all over the map. NHRA needs to choose one brand that is readily available (after all they are only doing this because stock castings are to hard to find for a SBC) and apply whatever HP they show!
PJ305 is offline   Reply With Quote
Old 12-22-2017, 01:35 PM   #34
Erik Jones
Liked 47 Times in 6 Posts
Everyone needs to realize that we all need replacement heads if we want to continue to race Stock And Superstock. The replacement head has to have the same spec as the OEM it is replacing. This is no different than the FE Ford, Big Block Dodge and Big Block Chevy. If anyone thinks the port shape is worth something major in a .400" lift Stocker you probably read to many "High performance Books".
Just relax and grow with the times....
Erik Jones
Erik Jones is offline   Reply With Quote
Old 12-22-2017, 02:24 PM   #35
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Junior Super Stock
Good point !
That makes Pure Stock the New STOCK !
Saw it coming !
Not sure it is a bad thing.
More racers will select these heads over time.
Hope it simplifies Tech seeing the same Head on more cars.
D
Old 12-22-2017, 02:41 PM   #36
nolongerracing
Liked 72 Times in 27 Posts
So... how do you plan on getting the 172 cc intake port down to 165 cc without epoxy or welding? That's the problem.
nolongerracing is offline   Reply With Quote
Old 12-22-2017, 02:55 PM   #37
ron mattson
Liked 68 Times in 31 Posts
the mopar 273 has a replacement head WAY bigger than factory cc so do some others, if you live in a humid climate you would welcome the not rusting property
of aluminum.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 12-22-2017, 04:29 PM   #38
Erik Jones
Its actually pretty easy. Thats what we get paid to do.
Erik Jones
Old 12-22-2017, 05:01 PM   #39
KEN BUGAJ
Liked 18 Times in 7 Posts
Sounds like NHRA now has Crate Motors !
KEN BUGAJ is offline   Reply With Quote
Old 12-22-2017, 05:26 PM   #40
nolongerracing
Ok... .140 off the intake rail and some extra, extra thick intake gaskets!!!
