Old 12-10-2017, 06:42 PM   #1
DODGEBOY
Liked 4 Times in 1 Post
Default torque converter
has any body used a lite weight bolt together coan torque converter in a stocker and seen any gains they claim 6 to 8 hundreds not a cheap try thanks
DODGEBOY is offline   Reply With Quote
Old 12-11-2017, 07:32 PM   #2
Richard Kay
Liked 19 Times in 9 Posts
Default Re: torque converter
Someone must have tried an aluminum converter in a stocker or super stocker. It would be interesting to hear of the results.
Richard Kay is offline   Reply With Quote
Old 12-11-2017, 08:33 PM   #3
Rsmith38
Liked 28 Times in 15 Posts
When I inquired several years ago they did not make that converter for the 904 trans. Suggest you call and ask!
Rsmith38 is offline   Reply With Quote
Old 12-11-2017, 08:59 PM   #4
Richard Kay
A-1 Makes a converter for a 904 and for a 727. I don't know if Coan does but it would be nice to hear of any gains in et from an aluminum converter.
Valiantrich
Old 12-11-2017, 09:31 PM   #5
Hacksaw
Liked 312 Times in 175 Posts
I'd be surprised if you get much feedback, but consider this: every Comp car has switched and if money was not an issue....... would you rather have a CNC Billet machined piece or some guy bending the fins with a pair of pliers?
Hacksaw is online now   Reply With Quote
Old 12-22-2017, 11:00 PM   #6
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
http://www.dragzine.com/features/pri...er-converters/
In out stocker, 1 lb of rotating weight / accelerated weight, is worth .01 of ET...Our new bolt together is approx 4 lbs lighter than current steel ones.
I can't see 6 to 8 unless you are starting with a really heavy converter! The less HP you have the more the weight is worth. We are approx 700 hp at 3400 lbs.
ATI Racing
ATI Performance Products is offline   Reply With Quote
