Old 01-03-2018, 10:31 AM   #21
Chad Rhodes
Default Re: 1987 Grand National Stocker?
Originally Posted by JRyan View Post
Chad I think you nailed it right on the head there. Both with the newer stand alone fuel systems and with NHRA's ability to check and enforce the car. It would probably still be a pretty good combo.
Rick
Unless their is something additional in the tech manual that isn't published, the specs listed in the blueprints are housing size, number of compressor impeller blades, and compressor inducer diameter. I think stock appearing externally goes without saying, but that leaves A LOT of grey area in that turbo, probably 100hp worth
Chad Rhodes 2113 I/SA
Old 01-03-2018, 11:12 AM   #22
Bob Shaw
Liked 316 Times in 61 Posts
When I was running a turbo Buick NHRA made me remove the turbo an disassemble it.
They had all the internal specs. This was in teardown at a national event.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 01-03-2018, 11:24 AM   #23
Chad Rhodes
but how long ago was that? and why wouldn't they publish that information.
Old 01-03-2018, 12:32 PM   #24
vic guilmino
Liked 56 Times in 21 Posts
i am with Bob
nhra did the same to me
they have things that are not in the books
and i try to get them but it was a NO
i had no trouble with boost
15# on the line and 30 in the traps
stock tubro
Vic Guilmino 1129 STK
Old 01-03-2018, 12:43 PM   #25
jmcarter
jmcarter's Avatar
Liked 3,181 Times in 972 Posts
Perhaps after Ingersoll turned the Pro Stock ranks on their ear?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-03-2018, 01:07 PM   #26
keith ohanesian
Both the non intercooled and intercooled combos were horsepowered by non stock turbos. Nhra had no idea what to look for and thought a stage 3 turbo was stock. Apparently Dave Shultz before he died had schooled NHRA on turbos. After that they had all the turbo cars in the barns. The Gallina's were the only ones that ran a motec engine management system that was incredible. Now there are really good systems out that would help the "drivability". Plus dual calipers. That engine would have to make 450hp to be fast and at 30 pounds of boost it could be done once or twice.
No prep is king
keith ohanesian is offline   Reply With Quote
Old 01-03-2018, 02:33 PM   #27
Frank Castros
Liked 2,726 Times in 961 Posts
Freddie Vetter's GN was bad fast, our car and his qualified in the top sixteen at the Keystones one year and we both went to the barn, except he didn't want to take his car apart because he didn't know how to put it back together, so he took the DQ and went home, probably to play golf. He was a great guy, but not too good with tools. He used to keep his golf clubs in his truck just in case.
Old 01-03-2018, 04:45 PM   #28
vic guilmino
Frank what year was that
i think he had the front mount intercooler on the car
Old 01-03-2018, 08:44 PM   #29
Frank Castros
1986? Probably 1987 now that I recall.
Old 01-03-2018, 10:21 PM   #30
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: 1987 Grand National Stocker?
What is this "lifting" you refer to? These cars are meant to be run out the back door! As far as Buddy Ingersol ,he is a Buick Legend that really made pro stock look bad.
The more people I meet the more I like my dog
Kevin
