Old 01-11-2018, 10:02 AM   #1
sox
Liked 13 Times in 8 Posts
Default 94 Mustang Wheel Question
Buying a 94 GT Mustang and want to put 15x8 Draglites on the back and 15x31/2 on the front. Can anyone tell me back spacing to fit 275/60 Drag Radials on the rear and what size front tire will work. Also can you provide any pics on how they look with this setup. Thanks...
sox is online now   Reply With Quote
Old 01-11-2018, 12:52 PM   #2
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: 94 Mustang Wheel Question
You can probably find that info on Corral, just by searching and not even having to post.
http://forums.corral.net/forums/
Old 01-11-2018, 12:56 PM   #3
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
15 x 8 requires a 5.5 back spacing.
...or you can use:
15 x 9 with 6.0 bs
15 x10 with 6.5 bs
All 3 sizes will fit the wheelwell with 275 tire.
This pic shows my 95 GT with 15 x 8 ( 5.5 bs) using a 295-55-15 drag radial
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 01-11-2018, 01:33 PM   #4
sox
Almack, I like the 295"s. Do you have any rubbing issues at all?
Old 01-11-2018, 04:48 PM   #5
ALMACK
ALMACK's Avatar
You will have to roll the inside lip of the fender to prevent cutting the tire.
No rubbing issues on the backside
I/PS '95 Mustang GT
Old 01-13-2018, 04:52 PM   #6
sox
How about the front tires. Looking at a 15x 3 1/2 rim.
Old 01-15-2018, 08:21 AM   #7
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
I run mine with 15X10's on the back with the 30X9" Goodyears. 5.5" backspace but I had to clearance the front edge of the wheel well and roll the lip opening. I was rubbing when at speed with the tire roll-out. The sides would rub when the car squats good without rolling the wheel well. I think the disk brake 8.8 housing is 3/4" wider than the older drum brake cars.
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
