Old 02-13-2018, 04:20 PM   #11
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Re: Water in radiator rusty looking
You can put about a gallon of cleaning vinegar in the radiator and let it circulate for 5 or so minutes and let it sit over night and then water hose it out then fill the system with fresh water and circulate that for 5 or so minutes and dump it. It will clean out the rust and scale in the block and radiator, you just to flush it ienough to get the water back neutral.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 02-13-2018, 04:46 PM   #12
GTX JOHN
I trailered my old boy's Roadrunner Stocker to a radiator shop when he let it sit over a year with water in it.....They back flushed the system and that seemed to help out.
Although if it was seriously rusted =
I suppose you could blow out a freeze plug that way!
John Irving
741 Stock
741 Super Stock
Old 02-13-2018, 05:39 PM   #13
Todd Bailey
Liked 33 Times in 17 Posts
I actually added some cascade dishwashing powder to an old motor and it made a difference.
Todd Bailey is offline   Reply With Quote
Old 02-13-2018, 06:00 PM   #14
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Interesting
Dishwashers prevents water spots when dishes dry.
I like this.
D
Old 02-13-2018, 11:11 PM   #15
HammondRacing
Liked 6 Times in 4 Posts
Thumbs up Re: Water in radiator rusty looking
Thanks for the help
HammondRacing is offline   Reply With Quote
Old 02-13-2018, 11:45 PM   #16
MR DERBY CITY
Liked 8,052 Times in 1,529 Posts
I took my radiator to be cleaned at a reputable radiator shop. Although it used to be TABOO, many racers put a quart or so of antifreeze in the water....
Old 02-14-2018, 01:23 AM   #17
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I'm on the verge of ordering Evans Waterless Coolant for my cars. Thoughts or experience with that coolant?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 02-14-2018, 06:14 PM   #18
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
I use 2 bottles of Gunk Water Pump Lube. Goes in like milk. Comes out the same in the fall. Done it for years. No rust whatsoever? I still use a stock radiator.
55 Chevy is offline   Reply With Quote
Old 02-21-2018, 11:22 AM   #19
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Learned and used vinagar years ago. Someone put trans fluid instead of toyota red coolant in a corolla. I had to flush it out and used the clear vinegar and wuite a bit for this mess. Those jobs never went back to the mess makers, lol.
Took a few doses but car was eventually good w patience.
chris ok is offline   Reply With Quote
Old 02-21-2018, 12:04 PM   #20
Eman
Liked 133 Times in 76 Posts
Your results may vary, all I can tell you is what worked for me. Years of rust in the radiator with a SBC with iron heads and aluminum radiator. I tried every combo of additives and lubes from water pump lube to lucas additive and others in between and still had rust, always used distilled water. One year I actually read the directions on the bottle of Lucas coolant additive and it said do not use distilled water. Since then I use Lucas additive with gallon bottles of store bought drinking water. No more rust.
