Old 02-15-2018, 07:15 PM   #11
MR DERBY CITY
Liked 8,014 Times in 1,526 Posts
Default Re: Trans shields for 2018
Blankets are a viable option, Jegs sells them for a little over 100 bucks although the blanket SFI life is only two years.....I have seen that th 200 shield and between my shifter and bracket,my brace, and my floor it looks like a royal pain to attach.....
Old 02-15-2018, 07:30 PM   #12
Coleydog
Liked 53 Times in 38 Posts
Money grab, what else
Old 02-15-2018, 07:38 PM   #13
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Actually I've ran shields on stock tunnels and they will clear it's just a pain to deal with , when pulling trans in and out .
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 02-16-2018, 08:43 AM   #14
Liked 10,769 Times in 2,238 Posts
For sub 10.00 second cars don't forget the SFI 29.1 flex plate.
I think I will take all of the different SFI numbers that I have to have on my car and buy a lottery ticket with those same SFI numbers. That should be a safe bet.
Old 02-16-2018, 10:26 AM   #15
John Dinkel
Liked 263 Times in 68 Posts
Hey Larry, you got a great idea. Any money left over will buy some gas.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 02-16-2018, 10:54 AM   #16
Kris Kristofferson
Kris Kristofferson's Avatar
Does anyone use the CSR shield option?
https://www.summitracing.com/int/par...-837/overview/
I remember trans builder Hutch on Yellow Bullet was going to try to manufacture one as well...he might be more motivated now that this new rule comes into effect..
Kris Kristofferson is offline   Reply With Quote
Old 02-16-2018, 11:48 AM   #17
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I haven't heard good things about CSR in a while in terms of product availability or company stability in general.
I'm a Glide guy but I feel that the SFI case is well worth the extra cost once in install one. It is so much easier to access the top bellhousing bolts and deal with the dipstick during installation.
S/ST 51
S/C 53
Old 02-16-2018, 12:07 PM   #18
Kris Kristofferson
Yes, I tried to phone the company (which in located in Florida I think) to directly order a shield and they were delayed quite a bit with production due to a lack of material. I am unsure how they are doing today.
I ended up buying a used CSR shield locally and it actually fit well on my TH-400 with a stock Monte floor. The trans was already out which made the install much better. I also used a Lokar flexible dipstick (which can have the certified locking end) which helped a lot and have also "hole sawed" some bellhousing acess holes (with covers in the firewall) to make installing the bellhousing bolts much easier..
I am just a bracket guy but hopefully this can help other guys..
Old 02-18-2018, 09:22 AM   #19
Kris Kristofferson
Hey guys, does anyone have connections with a good carbon fibre supplier? Hutch would make them if he could get a good source, he does great trans work you can check it out at YellowBullet..
I'm very aware and forecasted this year's ago. The problem is the carbon fiber people have worn me the heck out. I'm not sure what to do at this point.
Hutch
Old 02-18-2018, 12:29 PM   #20
Hacksaw
Liked 311 Times in 175 Posts
Try Tim Hodgins at Cynergy Composites 519 Two 4 Five 0016 Strathroy On
