#11 | |
If you have the Allison transmission, the gains won't be as impressive. The Allison has so much Torque Management programmed in it's computer (TCM) to protect it, that thing calculates the torque output, and tells the ECM to pull the timing back to protect the transmission. I had one truck with that transmission, and hated it. The 4 speed 4L80E trucks are much faster, use less fuel, and tow trailers better. Performance gains with the Allison are not nearly as noticeable. On my chassis dyno, the Allison trucks gained very little. I towed with a gasoline motor home a few years ago, with an 8.1L & 4L80E, it towed my trailer easily, and never an issue.
Ed Wright 4156 SS/JA |
#12 |
Liked 880 Times in 311 Posts
Yes, Ed mine has the Allison 1000 Trans.
I read an article about "Limp Mode" in the transmission if you modify the engine and the two computers don't communicate.
Adger Smith (Former SS) |
#13 |
Liked 91 Times in 29 Posts
Ed, do you have a tune setup for a 7.4 chev in a 2000 1 ton dually auto. The fuel mileage when towing is brutal. Your always looking for gas station.
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
#14 |
Liked 28 Times in 15 Posts
My 96 Crew cab 7.4 auto towing a 10K trailer gets 8 - 9 MPG at 65 MPH
Is that the range you get? |
#15 |
We sold our motorhome, if I get to race again I will be back to towing with my '99 7.4L Suburban. If I don't run much over 65, it gets 8 to 10, depending on hills & head winds.
Oklahoma has a 75 MPh speed limit on it's turnpikes (lots of toll roads in this crap hole state) mileage falls off a cliff @ 75/80. My 454" tows easier on much less fuel at 60/65.
#16 |
My truck gets 6 to 8mpg on a good day towing @ 60mph
#17 |
Liked 354 Times in 120 Posts
ED could you PM your address and turn around time. Thanks Tom
Tom Meyer 5240 SS Stock ??? |
