Old 03-27-2018, 02:31 PM   #11
Default Re: What does "NES" (No Engine Specifications) mean...
Originally Posted by Fireofficer5 View Post
That sucker was fast, with his 80 mm TB.
It was worth 1.2.
No problem ,bro.
We don't have tech in NHRA anymore either.
Old 03-28-2018, 09:53 AM   #12
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Definitely some engine changes for those cars in that year range. Early ones had the aluminum intake manifold with forward facing throttle body, later had a plastic intake with throttle body facing the driver side. I believe the plastic lower intake on the later ones is the same as Mustang with just the aluminum upper elbow being different to point to the opposite side. Both intakes are pretty restrictive. The plastic one also always cracked and leaked water, I don't think the updated part number with the aluminum water crossover is in the engine specs, would need to go through the process of getting that approved. There should be a cylinder head change somewhere in that year range, the ports got straighter at some point, I think around 96.
K Danner STK 468
kdanner is offline   Reply With Quote
Old 03-28-2018, 03:45 PM   #13
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
There was a Cougar I think in O/SA at Bradenton NMCA..No. 1 Q. 11.88? I know nothing more about it and would want to check into it. Sound awful fast..Too fast, if you get my drift.
I saw that as well.
My first thought was WOW !...that's one quick 2 valve
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 03-28-2018, 03:50 PM   #14
ALMACK
ALMACK's Avatar
I was thinking the 96 Mustang 4.6 combo was more favorable that the 91-95 combos
I/PS '95 Mustang GT
Old 03-28-2018, 05:12 PM   #15
Wink Re: What does "NES" (No Engine Specifications) mean...
Originally Posted by ALMACK View Post
I saw that as well.
Easy enough to figure this one out.
I'd like to extend an invitation to this fellow to bring that thing to the US Nationals.
There will be a fella there named Travis Miller..Long time Ford man. He'd love to check that car out.
Old 03-28-2018, 08:44 PM   #16
kdanner
kdanner's Avatar
Oh most definitely. The one rub is the cracking intake I mentioned. I think also look at it from the respect of when they fit the same class with the same engine, hence the same weight, punching the smaller hole in the air has to be beneficial. Plus that Mustang bodystyle has so many more engine combinations if a change is ever desired.
That guy's own words in recent months on a Tbird/Cougar forum:
"it has a big cam, big intake, big compression, big heads and big cubes"
"TFS intake, TFS heads, 90mm maf, 3.5" intake tube, 75 mm throttle body (too small), Bullet custom cams, 12.5/1 comp ratio,
big bore/stroker 5.3 Liter, Eagle crank, eagle rods, SHM 1 7/8"-3" long tubes, 4500 stall converter, 4:56 gears. E-85 for fuel."
K Danner STK 468
Old 03-28-2018, 09:34 PM   #17
Best running 2V 315, I mean 281, I've ever seen.
Old 03-28-2018, 09:44 PM   #18
kdanner
kdanner's Avatar
I think worse than that, a 323. Looks like the 3.75 Eagle crank plus a 3.7 bore.
K Danner STK 468
