Old 05-01-2018, 11:33 AM   #1
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Default Ford Focus?
Wow! 2017 Ford Focus RS added to the guide.... interesting.. at 298 HP
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 05-01-2018, 12:01 PM   #2
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Default Re: Ford Focus?
Gonna have to add a few pounds to the shipping weight just to meet the min. wt. for AAF/S class with 11.0 lbs. per hp break.
With a 13.50 1/4 mile index that car will easily run index, IMO.
Traction should not be a problem with AWD.
That's pretty stout h.p. numbers for a 2.3 cyl. 4 banger. Factory rated @ 350 hp.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-01-2018, 12:03 PM   #3
Steve Stickel
NHRA has it at 298 hp and at a 10.91 wt break, means 3252 lbs, as I see it... Maybe an natural F car.. Ford has it at 350 hp, and 350 ft lbs tq.
Steve Stickel
1161 Stk
1167 SS
Old 05-01-2018, 12:12 PM   #4
ALMACK
ALMACK's Avatar
I was thinking F/Stock also seeing as how it is All Wheel Drive.
That means it would then have an index of 11.80.
It will be interesting seeing the first AWD Ford, because you know someone will put a roll bar in one and load it with race fuel and turn up the boost
I/PS '95 Mustang GT
Old 05-01-2018, 12:13 PM   #5
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
What transmission , an automatic 10 spd ? If it is a stick , is there a scatter shield available ? Could be a fun car to run , if you put in the effort .
Old 05-01-2018, 12:19 PM   #6
ALMACK
ALMACK's Avatar
6 speed manual.
No Focus RS ever came with an automatic.
As far as a scatter shield, this may be a first for NHRA. Not sure tho.
If it is a F/Stock car, then it will be the first AWD in that class area that falls under the rules of the rear wheel drive cars.
This is a qoute from a online article about the car:
This led Ford to work with the engineering company GKN on the Torque Vectoring Rear Drive Module (RDM), which looks like a rear differential with electronically controlled but hydraulically actuated clutches on each rear-wheel output. A dedicated computer monitors vehicle sensors 100 times per second and locks and unlocks the clutches given the situation. The clutches allow the Focus RS to transfer up to 100 percent of its available power to the left or right rear wheel within .06 seconds by fully opening one clutch and locking the other, or it can lock the rear axle solid when using launch control.
https://www.roadandtrack.com/new-car...asts-hope-for/
I/PS '95 Mustang GT
Old 05-01-2018, 07:48 PM   #7
ALMACK
ALMACK's Avatar
I just got confirmation.
It is treated as a rear wheel drive so it's a E, F, or G stick car.
I would be curious how a racer will get around the SFI bellhousing rule with the transmission arrangement in that car
I/PS '95 Mustang GT
Old 05-01-2018, 09:12 PM   #8
nickh
nickh's Avatar
Liked 636 Times in 189 Posts
Wonder if Steve Polhill has thought about this combo lol
Old 05-01-2018, 09:20 PM   #9
ss3011
ss3011's Avatar
I think the rulebook allows some sort of shield if no one makes a bellhousing . You must have a SFI flywheel , so that might be a problem . It just takes a little perseverance .
Old 05-01-2018, 09:39 PM   #10
ALMACK
ALMACK's Avatar
I'm going to read the rulebook tomorrow.
That car uses the MMT6 Ford Transmission.
I saw some pics of that trans. That would be tough to make a SFI BH.
A SFI flywheel looks doable, but super expensive I would imagine.
Those cars are $ 35K + when new. That could turn out to be one expensive Stocker.
