Old 05-08-2018, 11:20 AM   #1
SC1448
Liked 2 Times in 2 Posts
Question Hard-Tail Dragster Battery Recommendations?
My just 3-year old Optima Red Top 800 CCA crapped out (like a switch was flipped on it) Sunday to knock me out while in the lanes heading into E3. Not Happy. Looking for recommendations for a 12-volt replacement. I know Optima specifies vibration resistance but, they're probably not the only one. I know there's a lot of guys on the 16-volt program but, not ready to make that switch at this point. Odyssey looks like one to consider but, do you need their charger to or???
As always, all replies are appreciated!
Thanks!
-Don
SC1448 is offline   Reply With Quote
Old 05-08-2018, 04:03 PM   #2
Hacksaw
Liked 311 Times in 175 Posts
Default Re: Hard-Tail Dragster Battery Recommendations?
Take a look a Braile, out of Fla.
Old 05-08-2018, 04:53 PM   #3
JR fuel
Thanks!
-Don
I would look at the Braille ! I was working in the lanes on Sat and saw what happened ! Not a good way to loose a race ! I also noticed that Amanda tried to wait for you ! Nice to see stuff like that !
JR fuel is offline   Reply With Quote
Old 05-13-2018, 09:22 AM   #4
mike withers
Liked 3 Times in 1 Post
odyssey battery hard to beat had them for years
Mike Withers 1195 SS
mike withers is offline   Reply With Quote
Old 05-13-2018, 10:27 AM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The best place I have found to buy Odyddey batteries: Batterymart.com
https://www.batterymart.com/c-odyssey-batteries.html
If you want less weight do not buy the MJ series (metal jacket). Your other question was about chargers, I do have their charger. Here is a list of approved chargers for their batteries.
http://www.odysseybattery.com/docume...V_chargers.pdf
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 07-18-2018, 11:59 AM   #6
voltdr
Liked 100 Times in 51 Posts
This is good info about using the correct charger for the battery. The days of using the repair garage type charger is long gone. I recommend using the same brand of charger as the battery. That way if you do have an issue, they can't say you used the wrong charger.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
