Old 05-16-2018, 05:29 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Front tire pressure adjustments
Will lowering my front tire air pressure slow my reaction time down. I run 40 lbs. is that normal or high or low.?
Kdw1403 is offline   Reply With Quote
Old 05-16-2018, 05:31 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Front tire pressure adjustments
should!- pressure compared to what?
Old 05-16-2018, 05:41 PM   #3
Kdw1403
3200lb stocker 98 camaro.
Old 05-16-2018, 05:52 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
That's pretty high, but not crazy. Lowering the pressure will slow your reactions, but there isn't a ton there if you are keeping the pressure within reason.
I run 32-35 psi in my 3600# Super Street car. I typically bracket race it, and use starting line RPM to adjust reaction rather than tire pressure.
I can't tell if your question is:
1. I run 40 psi in my tires and I think it might be too high, but what will happen to my reaction times if I lower the pressure?
2. I need to slow my reaction times. Will lowering the pressure in my front tires accomplish this?
If #1, I'd probably drop 5 psi and you likely won't notice the difference. If #2, I'd still drop 5 psi, but you'll get more change in R/T through RPM adjustment or rear tire pressure.
S/ST 51
S/C 53
Old 05-16-2018, 06:14 PM   #5
Lee Valentine
Liked 319 Times in 68 Posts
More in lowering rear tire pressure so they wrinkle more.
Lee Valentine 1661 STK
Old 05-16-2018, 06:44 PM   #6
Kdw1403
I am trying to slow my reaction time down. When I am green it is is about a 015-020 But I go red alot by about .012-.015. Don’t win many races when you go red. Just trying to slow down reaction time without changing my spot on the tree. I might need to lower both front and rear tire pressure. I know I could lower my starting line rpm some as well. Just try to see what you guys think the best way to do it is.
Old 05-16-2018, 07:57 PM   #7
Hacksaw
Liked 311 Times in 175 Posts
Put a taller front tire on, if you have the room.
Old 05-16-2018, 08:10 PM   #8
Brett C
Liked 1,018 Times in 217 Posts
Drop leave rpm down just a tad.
Brett Candies
4192 Stock/SS
God Bless America
Old 05-16-2018, 08:11 PM   #9
HR9121
HR9121's Avatar
Not sure what size front tire you run but I run a 28" with 25 to 30 psi depending on roll out but as Lee stated don't overlook the rears. There's alot you can do there especially if you run bias ply tires.
James Williamson
W200 J/SA. SS/JA
Old 05-16-2018, 08:18 PM   #10
jmcarter
jmcarter's Avatar
I’ve generally just lowered the RPM to slow RT, doesn’t seem to affect ET as much plus you can adjust that or not “on the fly” if you see everyone spinning like crazy or you’ve just packed in 50 pounds of lead. You can add some shock extension too and of course what Hacksaw said but probably don’t have much room on a late Camaro. Assume you’ve verified the car isn’t periodically pulling straight up out of the beam?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
