Old 05-17-2018, 09:30 AM   #21
jmcarter
jmcarter's Avatar
Default Re: Front tire pressure adjustments
What’s the best source for a brake pressure switch? I’ve also avoided a button on the brake petal, just another thing to put in the starting line procedure.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-17-2018, 09:33 AM   #22
Kdw1403
Liked 68 Times in 22 Posts
Sorry but I do not have a brake pressure gauge. Sounds like I need to install one. My car is fuel injected. Will I need to change my tune up while I am on the 2 step. My car work really good running off the foot brake. Im very new to stock and the fuel injection game. Thanks.
Kdw1403 is online now   Reply With Quote
Old 05-17-2018, 10:04 AM   #23
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Originally Posted by Eric Merryfield View Post
You have some good suggestions here.
Just to complete the logic circle, you do have a brake pressure gauge in the car and know what brake pressure you are staging at correct? Don't have time to look, etc, get a go pro and video the gauge. If your not consistent with that then there you go.
Two step, could help, depends on your carb and how it works when floored, you may also want to upgrade to a brake pressure switch, instead of the brake pedal piece.
Log books should give you a clue too. Time trials versus competition etc.
Change one thing at a time.
Eric
What benefit is there to the brake pressure switch over the brake pedal switch two step? Thanks for the help in advance.
Old 05-17-2018, 10:37 AM   #24
Dave Gantz
Liked 251 Times in 125 Posts
Do you use a practice tree? I found that it helped me narrow down the range of the lights I was cutting. Then I was able to zero in on when to leave.
Of course, if they eliminated reaction time, none of this would matter. :-)
Old 05-17-2018, 10:52 AM   #25
Bobby DiDomenico
Liked 101 Times in 52 Posts
At the least it would require the same brake line pressure each time you stage. Eliminates a variable.
Old 05-17-2018, 10:58 AM   #26
rboyle
rboyle's Avatar
So then you prestage bump in and check brake pressure then look at the tree and get on the two step? I don’t mean to sound synical, just want to make sure of the process and if this would help me
Old 05-17-2018, 11:16 AM   #27
tony wood
Liked 42 Times in 17 Posts
ok this is gonna sound stupid but try ankle weights used them on my stick super stocker was going 10-15 red try 5pd weight
tony wood is offline   Reply With Quote
Old 05-17-2018, 11:31 AM   #28
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
You can microadjust the brake pressure switch to release at a higher or lower pressure as your needs and car may like.
Everyones staging method is different, I don't look at the gauge, I listen for the two step if I am running it. My dakota fuel injected two step process is totally different than the footbrake gremlin(I don't run the pressure switch two step on it, just a gauge)
Two step is just faster for some cars/trucks. I like footbraking more.
Even better is a stick, now that is where the fun factor really comes in, lots of variables you can tweak to adjust RT, but don't ask me specifics, I'm a novice.
Eric
Eric Merryfield 1883 STK
Old 05-17-2018, 01:06 PM   #29
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
Okay, if you're not blocking or blinding, let's leave that for another day.
Now, by your own description, you're swinging across .000 by about 35 thou.
So let's say you slow your vehicle reaction down .035. Your - .020 now becomes a +.015
Great.
But what happens when you hit what used to be a +.015? It now becomes a + .050.
Not going to win too many that way either.
My friend, I think you need to work on something other than the car right now.
Just my opinion. I don't consider myself to be a bracket racer. I did win a couple of track championships, but I think I'll let the experts take it from here.
Later ,we can get back to the technical items.
Good advise here. Your car if set up the same each run is going to react in just about the same amount of time each run, the variable is the driver. I worked my super gas car down to decent repeatable lights on a Pro tree. I then ran it in super street and was consistently early. (I needed to adjust the car to the slower light) That was accomplished with making changes to the car. Then I went and ran some full tree classes and I was all over the place. The car was still the same and I knew it could cut decent lights on either Pro tree. The difference in the full tree races was squarely with the driver, me. I needed to find a way for the driver to be better at reacting to the full tree, blocking or leaving on the top bulb are some of the ways to accomplish that.
Old 05-17-2018, 02:27 PM   #30
superstock45
Drop front to 17psi
superstock45 is offline   Reply With Quote
