Old 06-23-2018, 12:02 AM   #11
Coleydog
Liked 53 Times in 38 Posts
Default Re: K-frames on Mopar
Originally Posted by Tom Broome View Post
AND While you're at it. When you brace that steering box mount.....don't you DARE cut it off and move it over for more header clearance.
Sounds like someone got caught. Could drill the holes bigger and use an offset bushing, or would the powers that be say thats a no-no?
Old 06-23-2018, 09:25 AM   #12
Dave Gantz
Liked 251 Times in 125 Posts
Red face Re: K-frames on Mopar
They'd probably say no. It's hard to tell what's okay anymore. But they'd probably never know unless someone posted it on an open world wide web forum, that they've been known to read.
Old 06-23-2018, 10:23 AM   #13
Coleydog
Oops, I get your drift.
Old 06-23-2018, 02:28 PM   #14
CMcAllister
Liked 920 Times in 259 Posts
If you inclined to spend the time doing so, properly welding any body and chassis components, that were half ***** spot welded together with the QC of the 60s and 70s, will make a big improvement in any uni-body car. For the most part, they are pretty flimsy.
Old 06-23-2018, 10:29 PM   #15
Liked 10,836 Times in 2,252 Posts
And if you do move the steering get ready to spend a little time on adjusting bump steer, with long and short tie-rods. Its never something for nothing.
Old 06-26-2018, 10:27 AM   #16
Tom Broome
Liked 88 Times in 43 Posts
Sounds like the voice of experience.
Or you could reconfigure the center link.
Tom Broome is offline   Reply With Quote
Old 06-26-2018, 12:03 PM   #17
Bump steer is always very time consuming, but on box relocation I have zero experience.
Old 06-26-2018, 08:42 PM   #18
Tom Broome
Bump steer is always time consuming, especially if you're bending parts to adjust.
I don't think I have seen a Hemi Dart/Barracuda that hasn't had the box moved some. I always thought Hurst slotted the boxes.
Old 06-26-2018, 11:52 PM   #19
Coleydog
The box is a stupid amount of distance from the frame.? Even the steering shaft is angled toward the engine and the whole drivetrain is offset over an inch or more to the right. At least I got the spindle to stay zero thru the up and down travel. Bump steer next. Got a hot torch and BFH.
Old 06-27-2018, 07:58 AM   #20
Tom Broome
Make sure you have your caster and camber dialed in before you start the bump steer process. Ideally you should have the center link at the midpoint of travel to start, with the plane of the front wheel parallel to the centerline of the car or rear track (your choice).
No matter what, once the first side is where you want it, you don't get to move the steering angle at all. And...that should be the position the steering is located as the car goes down the track.
