Old 08-11-2018, 12:36 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Trailer based weather station
pole mounts.
Post your photos.
TIA
Old 08-13-2018, 12:02 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Trailer based weather station
I don't have a photo, but I have this Plattinum Products mount set. One piece to hold the weather sensor unit inside the trailer during transport, and a tube to securely support the bottom of the pole outside the trailer:
https://www.ebay.com/itm/Plattinum-W...sid=m570.l1313
At the top trim of the trailer, above the support tube, I use one of these to secure the top of the pole:
http://www.biondoracing.com/product/ALB-QC2-2.html
S/ST 51
S/C 53
Old 08-13-2018, 12:12 PM   #3
Lenny5160
Lenny5160's Avatar
I found a photo that isn't very detailed but should at least illustrate what I posted above:
S/ST 51
S/C 53
Old 08-13-2018, 04:12 PM   #4
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Ed, I use 3 of the following, coulda probably gotten by with two... but the Cold War made me a believer in overkill, lol!
https://www.amazon.com/dp/B000CQPANY..._xwECBbZYJH2XC
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 08-14-2018, 08:15 AM   #5
1320racer
1320racer's Avatar
Thanks for the replies.
Pete, I have 4 of those clamps enroute. I believe they are also the same ones that Altronics sells.
I also have these brackets coming that Computech uses and I'm using the same pole...
That Platinum Products bracket is trick for transporting the weather station head inside the trailer...
Also found this pole mount which would work too...
https://www.shop.flagpolebuddy.com/S...Dia-106961.htm
available in 1", 1.5" and 2"
Old 08-14-2018, 10:34 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,924 Times in 578 Posts
I use the rubber ones from Altronics. 2 on the exterior and 2 inside for storage. Easy to use and won’t rust. I store my trailer inside. If you store yours outside in the elements then the rubber ones might break down after a few seasons.
Mike Pearson 2485 SS
Old 08-16-2018, 08:10 PM   #7
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
I have to say this thread has made me get off my butt and finally make a mounting pole for my wind meter. Now mine is just a $50 weather station from TSC cause I’m a poor boy but, as long as it gives me wind speed I’m happy.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 08-18-2018, 10:06 PM   #8
1320racer
1320racer's Avatar
I ended up using the brackets that Computech uses/sells, shown in the video below.
Thanks again for the replies.
Old 08-24-2018, 01:06 PM   #9
1320racer
1320racer's Avatar
