Old 08-15-2018, 12:08 PM   #21
FED 387
Liked 333 Times in 180 Posts
Default Re: Lighter wheels = any E.T reduction?
Gentlemen--- Car Craft Magazine had an article a while back whereby they tested different transmissions and the Horsepower required to turn a transmission. I do not know if these are totally stock trans or were modified in any way, I also do not know if theTorque Convertor was used in these tests. These are THEIR results:
Powerglide---18 HP
Turbo 350-----36 HP
Turbo 400-----44 HP
C-6--------------55-60 HP
C-4--------------28 HP
A904------------25 HP
727--------------45 HP
Old 08-15-2018, 12:20 PM   #22
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Lighter wheels = any E.T reduction?
Originally Posted by 340Cuda View Post
I guess we have all bought a lot of stuff that was supposed to be good for a tenth and were disappointed.
However a long time ago Paul Forte told us one of his 904 transmissions would be a tenth quicker than the 727 we were running and he was right.
I am guessing about half of that was less static weight and the other half was reduced rotating weight.
I read about the 727/904 difference decades ago. There was an article (maybe in the Direct Connection manuals) where Paul was testing with a few Stock and/or SS cars around the mid-'70s. I remember the difference being stated as .15, with everything else being made as equal as possible. (converter, weight, etc.)
Physics says that any weight reduction will help a race car accelerate faster, even if it's rotating and the same reduced amount replaced with static weight. But any of the small gains can often be masked by some of the many other variables that can't be consistently and minutely controlled.
My theory has always been to try things that "might" help.....as long as there was a certainty that it couldn't hurt.....and you could afford it. Unfortunately, the "afford it" part usually restricts me.
LOCOMOTION Racing
Old 08-15-2018, 12:28 PM   #23
Myron Piatek
Powerglide---18 HP
Turbo 350-----36 HP
Turbo 400-----44 HP
Somebody also had an interesting comparison of differential efficiency. I don't recall who, but do remember that a Dana 60 and GM 12 bolt were at the top while the Ford 9" was at the bottom. Mopar 8 3/4 was in between, but I don't remember what else was included.
LOCOMOTION Racing
Old 08-15-2018, 05:55 PM   #24
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
The Rotational benefit from lighter wheels is minimal.
Losing weight going to a aluminum vs steel wheel is a benefit.
Less Friction from meshing or rolling parts would offer bigger gains.
Or going to a Radial Tire vs Bias.
Old 08-15-2018, 07:18 PM   #25
Rick Kolber
Liked 32 Times in 13 Posts
Many years ago one of the popular magazines did a drag test using a stock vehicle and comparing the difference in et between stock steel wheels and aluminum racing wheels..weight difference approx. 60lbs and approx. .010 difference in et. More recently on the Hot Rod Network there was a redo of that test but there findings were 80lbs difference which meant .011 and 1mph gain. The whole scenario is if you keep taking rotational weight off here and there it all adds up..the more the better. Again not for someone on a budget. Just my opinion
Rick Kolber is offline   Reply With Quote
Old 08-15-2018, 09:57 PM   #26
Ed Wright
Ed Wright's Avatar
If the magazine tested wheels on a stock vehicle, they would see more benefit than a race car, due to HP difference.
As for transmissions, my T350 Pro Trans with lower dia & lighter internals (and other things I likely don't know about) is a solid min 5 hun quicker than another well known/professionally built T350 I had.
Ed Wright 4156 SS/JA
Old 08-16-2018, 09:38 AM   #27
Jim Caughlin
Liked 805 Times in 245 Posts
Originally Posted by Bob Mulry View Post
The further away from the centerline of rotation the greater benefit of rotating weight reduction..
Remove 1 pound of rotating weight from the OD of the flywheel vs. a 1 pound reduction from gun drilled axles.....
It's called moment of inertia.
Just sayin'
Flywheel weight vs wheel weight is a totally different situation. When I reduced the flywheel/clutch weight and dia, I got HUGE results.
Jim
Jim Caughlin is offline   Reply With Quote
Old 08-16-2018, 12:50 PM   #28
Tim Kish
Liked 11 Times in 4 Posts
Jim
Car probably slows down - on the low HP stuff there isn't enough power to get the car moving if the flywheel/clutch is too light, need that inertia to not bog it down....
I'd say my low HP car doesn't repeat well enough to measure gains of a few hundredths, weather and wind move it more than that run to run.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 08-16-2018, 05:37 PM   #29
voltdr
Liked 100 Times in 51 Posts
Because we can't test in a "vacuum", our test results are subject to interpretation based on any differences in track surface, track temps, wind direction changes, and any other number of variables. I do believe that if you apply all of the things that are supposed to be better, then it will be better. You just may or may not see the results immediately.
It's the same in my electrical business, I can guarantee that you will use less electricity by switching to a more efficient electric motor or LED lights, but you might not see a difference in your electric bill due to differences in running time of all of the components are different each month.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 08-23-2018, 12:57 AM   #30
Chad Fergen
Liked 24 Times in 12 Posts
Originally Posted by RJ Sledge View Post
My old friend Charlie Ford told me over 30 years ago that "If everything I bought that was suppose to pick me up a Tenth or so was true.....I'd be going zero right now!"
Ain't it the truth......lol
RJ
Ha! That is a "Classic" #loveit
Chad Fergen is offline   Reply With Quote
