Old 09-02-2018, 05:35 PM   #1
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Default Quadrajet Needle & Seat
What is the best needle and seat for a Quadrajet? This is for an Ashley stocker carb, return style fuel system, and 6.5 lbs fuel pressure.
Windowed - Non Windowed ?
Best diameter - .124" .125" .132" .135" ?
Best place to purchase and part numbers would be appreciated.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 09-03-2018, 12:00 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Quadrajet Needle & Seat
If you can find them, the Grose-Jet assemblies are the best.
Once in a while you can find them in Ebay.
Also, Jet Performance carries all sizes of QJ needle & seat assemblies.
Old 09-09-2018, 10:37 PM   #3
monte385
Liked 27 Times in 19 Posts
Edelbrock used a .149 in there 1910 Qjet. You can drill em & experiment.
monte385 is offline   Reply With Quote
Old 09-11-2018, 11:00 AM   #4
nhramnl
Liked 358 Times in 83 Posts
Dean Oliver would tell you to stay away from the .149 Edelbrock needle and seat. He says he has helped a lot of racers who were having acting rich/flooding-type problems simply by having them switch to a smaller, "traditional" orifice size. He helped me with a car that was so blubbery at idle and around the pits that it would actually smoke gray. I switched the needle and seat, verified the float setting (it was right) and I had a different car. Dean's theory is that the .149 passes so much fuel that it creates turbulence that prevents the float from seating properly, which obviously makes the car flood.
Old 09-11-2018, 11:09 PM   #5
monte385
He would know. I'd say depends on fuel pressure, I'm running .144 with 6-6.5 psi in my street car.
Old 09-12-2018, 07:21 AM   #6
nhramnl
I agree completely and probably should have said that. Dean said that some carb/engine combinations seem to get along fine with the .149, but when somebody calls with a "No matter what I do, the damned thing acts real smoky rich at idle and at slow speeds", the first thing he asks them is "Do you have a "big" needle and seat in the carb?". If they do, he tells them to take is out and replace it with a smaller one. I was honestly skeptical of something that simple fixing my problem, but the problem literally disappeared. Dean has been my 4GC and QuadraJet guy for many, many years, and has never given me bad products or advice.
Old 09-12-2018, 01:03 PM   #7
Chad Fergen
Liked 24 Times in 12 Posts
Great topic Dean. I'm hearing "smaller" than .149. How much smaller? I know mine is bigger that the .125 as my 1/8 drill bit is loose. I will check it with pin gauges at work today(on break of course... ) and let you know. There are several on ebay under "quadrajet needle".
Chad Fergen is offline   Reply With Quote
Old 09-12-2018, 01:06 PM   #8
Chad Fergen
One more question that might play into this. I see they have different weight floats. I would think that that might have some effect on the seating of the needle. Thoughts?
Old 09-12-2018, 03:42 PM   #9
nhramnl
Just call Dean direct and he'll evaluate what you've got and make a recommendation. Dean Oliver - 870-830-5470
Old 09-14-2018, 07:14 AM   #10
Todd Hoven
Guest
Posts: n/a
That size can be very temperamental. Anything over 5 psi with that size can cause the carb to flood over at any time.
I found the .135 size with a window works well. Anywhere from 6.5 to 7.5 for fuel pressure works for this.
