#11 |
Liked 333 Times in 180 Posts
Federal industry wide ratings any tire with a ST rating is rated for a maximum speed rating of 65 MPH at the proper inflation.
#12 |
Liked 24 Times in 17 Posts
Not all are rated at 65mph. Some of the ST tires are speed rated "L" at 75MPH. The Hercules H-901 225/75/15 is Load Range F and Speed Rated L (75MPH)
#13 |
Giving this a little bump as I will be swapping out my 2 year old Westlakes around Feb 19. Anyone else running these yet?
#14 | |
Liked 369 Times in 127 Posts
The trailer pulls so much better now. ![]() I had to go to 16 inch wheels to use the LT225-75-16 Truck tires. LT truck tires are the way to go, IMO. Anyways, my trailer uses 5 lug 4 1/2" bolt pattern. I was amazed to only find one wheel company that made a 16 inch- 5 lug 4 1/2 inch bolt pattern wheel in steel. Last edited by ALMACK; 11-19-2018 at 08:25 AM. |
#15 |
Where did you find the 16 inch wheels with the 5x4.5 bolt pattern?
#16 |
Liked 973 Times in 310 Posts
Any updates from using these Hercules trailer tires 15"
#17 |
I have been running these all year. Only have around 5-6K on them but so far so good. They really track better than any other trailer tire I have used.
I run around 90PSI in them, They are on a 28FT ATC with 3500lb car, golf cart, tools etc weighing in around 9800. |
