Old 10-10-2018, 08:17 PM   #1
Gregg Luneack
Liked 225 Times in 30 Posts
Default 8 3/4 MOPAR Ring & Pinion
8 3/4 Mopar ring & pinion , 742 case 5.33 ratio,used, good condition
10 spline, $150.00
8 3/4 Lightweight steel spool with bearings, used, good condition
for 30 spline axles, $150.00
8 3/4 pinion yoke, large u joint [ 7290] 10 spline, used $45.00
8 3/4 pinion yoke, small u joint [7260] 10 spline, used, $35.00
8 3/4 pinion yoke, large u joint [7290] 29 spline, used $ 45.00
1pr Centerline Convo-Pro 15x4 frt wheels, good condition, 4 1/2 bolt circle $250.00
1pr Centerline Convo-Pro 15x10, 5" back space, 4 1/2 bolt circle
no screw holes, good condition, $ 350.00 All 4 wheels $500.00
New M/T 29.5x10.5x15R Pro Bracket Radial Slicks, Never Mounted, $ 475.00pr.
Can deliver to Vegas or Pomona.
760-630-9094
Gregg Luneack is offline   Reply With Quote
Old 10-10-2018, 11:24 PM   #2
cyclonebfx
Liked 5 Times in 2 Posts
Default Re: 8 3/4 MOPAR Ring & Pinion
Just wanted to clarify, are the gears 5.33 or 5.13?
Thanks
5705 F/S
5706 D/SA
cyclonebfx is offline   Reply With Quote
Old 10-11-2018, 11:41 AM   #3
Gregg Luneack
Gear ratio is 5.33,32 teeth on ring, 6 on pinion , very rare.
