Old 10-27-2018, 06:09 PM   #31
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: When you buy sunoco make sure it's not methanol
I've run Sunoco, VP and Renegade
All 3 116 RED dyed fuels.
Never had any problem with any of them from any track or supplier.
VP has X-16 and its just not available anywhere but direct from a VP dealer. I was buying it from Jeff Stricker
I also ran the Q-15 blend for half a season a couple years ago.
Tried VP C-14 at one event this year.
Both C-14 and Q-15 fuels sucked in plain English....
VP prices are ridiculous and some of their fuels let off offensive vapors enough to make your head spin....Noxious !!
Sunoco Maximul from a pump or a sealed 5 gallon can runs well for me and is available most of the time.
I dislike buying VP fuel other than the X-16. If it was more readily available I'd buy it when Sunoco was not available.
Other than that one fuel I would not buy VP....Pretty much hate the stuff....
Had a Stocker in 2005-2006...Bought VP fuel usually at the track after pumping out what was in the cell and completely emptying the cell with a hand pump.
At the Cecil Lucas race ....I bought fuel there and a lot of guys were failing fuel check or nearly failing. I showed the NHRA guy my receipt for the fuel I just bought that was out of spec. Seemed to me at that race they let it slide.....to many cars were checking bad. VP fuel right out of the drum not right.....don't recall if it was C-12 or C-11.....That was the only 2 fuels I used at Lucas races with that car. One more reason I don't use VP if I can buy Sunoco...
I've run Alcohol a lot and its nothing like gasoline.....I think I'd know in a heartbeat I was putting methanol in my fuel cell and not race gas......Yea I'd be pissed to.......
Some gas pump jockey started putting gasoline into my diesel pickup recently. I caught it before he got much in there....Stupidity is rampant.....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 10-27-2018, 07:57 PM   #32
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by cmracing View Post
I don't know if his fuel got pumped from a drum, or from a pump.
we do know...
Originally Posted by Eddiejr2892 View Post
at Charlotte bought 5 gallons of 112 from sunoco, Come to find out that gave methanol at the sunoco truck .
it was the the fuel pumper's mistake at the truck and the OP's for not recognizing that he was pouring alcohol.
so again, what does he expect to be done?
Old 10-28-2018, 10:10 AM   #33
Future Super Stocker
Cool Re: When you buy sunoco make sure it's not methanol
Originally Posted by Charlie Yannetti View Post
OK.. OK.. so when are people going to reset their alarm clocks, and WAKE UP!!!.. with all of the nonsense surrounding Sunoco Race Fuels, my question would easily be, "IF YOU DON'T HAVE TO USE IT, WHY THE HELL ARE YOU USING IT??"..
We continue to hear horror story after horror story about the brand, but for some reason think that because it's the fuel of NHRA, we have to use it.. they can't test it in the Pro Stock cars, they can't test it in the Comp cars, they are probably still guessing in the Stk and SS cars, or just saying it's close enough, and they have even had problems with their methanol.. the stuff almost never tests right, has no shelf life, and has been a proven detriment in higher compression and horsepower cars... BUT, for some reason, those that don't have to use it, continue to use it, and those that have to use it get penalized in power, or parts...
I do understand that NHRA has made it difficult to get VP Race Fuels at some venues, but it is always available, and usually not to far off site.. giving up performance, changing tune-ups, and breaking parts make the trip to get VP worth it.. especially if you can use it in your class... how can racers get a DQ, when the product can't even be tested???
AND NOW, we hear that either they are not putting it in the right drums, or their race personnel just don't care, or suck.. OR ALL THREE.. how do you possibly mix up fuel for a Stk or SS car??... beyond me..
I actually was amazed to read an article where the NHRA VP of Competition stated that they went to Sunoco SR-18 as a way of slowing down Pro Stock.. might not be the exact words, but it is the meaning.. NHRA needs to be ashamed of themselves for ruining a class, and penalizing racers across the board.. and all just to stuff someone's pockets.. NO DOUBT!!
DON'T EVEN COME NEAR ME WITH THAT DIESEL FUEL!!!... and remember, if you don't have to use it, DON'T!!!
The Russians did it! Or, they are liberal Democrats that hacked the fuel.
Future Super Stocker is offline   Reply With Quote
Old 10-28-2018, 10:14 AM   #34
Eddiejr2892
Liked 6 Times in 4 Posts
The fuel was pumped from a 55 gallon drum into a brand new sealed 5 gallon can
It's not that I'm whining and complaining
It's bad that I spent 1500.00 to get to a national
Event and never get down the track or get to move on ladder , changed fuel pump, changed ignition , and carburetor,
The whole deal sucks and ruined my weekend
It was a mistake and shouldn't have happened but it did ,
Eddiejr2892 is offline   Reply With Quote
Old 10-28-2018, 11:26 AM   #35
Todd Hoven
Guest
Posts: n/a
The same thing happened to me at Atco about 25 years ago when I first started racing stock. Was supposed to be C12 and was methanol. It was a track mistake then a driver error. From that day on when I purchase a new jug of fuel or take fuel from a unfamiliar source, I spill a little into the cap or on the ground just to make sure its the right stuff.
Doesn't sound like a brand problem, sounds like a handling and racing management problem. Both fuels work great. You had a once in a lifetime problem that I'm sure won't happen again. Chalk it up to experience.
Old 10-28-2018, 11:45 AM   #36
1320racer
1320racer's Avatar
and it's on you!
EXACTLY!
Stop your whining and complaining!
Old 10-28-2018, 01:35 PM   #37
Charlie Yannetti
Liked 192 Times in 83 Posts
Thanks for your input Dave... and you're right, C-14+ and Sr-18 are not commonly used in Stock or Super Stock... BUT, I see that you have used C-25, probably in your SS car.. I just find it interesting that, at the time, C-14+ cross referenced to SR-18, and strangely enough, so did C-25.. I was confused by the wide band of coverage by one fuel..
While I'm sure that we could have a long term conversation about the two products, I can only offered my experiences, in the Super classes and Comp, the experiences of the teams I've worked with, along with the problems that I've witnessed on the dyno, and at the track..
We all know that there are those set-ups that are not too tempermental about what fuels go through them, and we also know the fuel costs, and availability, can be a deciding factor. It just bothers me that we racers pay a lot of money to do what we do, and at least we should be able to expect quality control, and consistency.. I have never had an issue with VP, but as described, I have had issues with Sunoco..
There are those guys on here, Dave and Rich, for example that I know have run the gambit with fuels, oils, plugs, parts, whatever.. they have each put in the time to compare different fuels, and found what they feel is best for them.. and their opinions are valued, and appreciated...
My point is not so much to pit one fuel against the other, cause I have, as much as to point out that since Sunoco has become the NHRA fuel, there have been too many problems in its use at events.. and yes, I may be referencing Comp and Pro Stock, but are those folks not racers too??.. failing fuel check, or being DQed after winning around affects all racers.. and I know that it has been happening in Stock and SS too.. just my opinion though..
I think it's time that both fuel companies be allowed on the property at ALL events, and let the racers be allowed to use the product of their choice, even Comp and Pro Stock... although this has happened at some tracks, it's not all tracks...
Charlie Yannetti is offline   Reply With Quote
Old 10-28-2018, 02:02 PM   #38
Rich Biebel
This thread got started by someone who was sold improper fuel by someone working for Sunoco.
That person obviously is the main reason the thread starter had a problem. Basically the guy put the wrong fuel in a can and the racer took it for granted it was what he asked for.
If you like VP and have had good results with it, buy it and run it.
If you like Sunoco and have had good results with it, buy it and run it.
Make sure you check it before you dump it in your fuel cell.
I transfer fuel from a sealed can to my jug OR get my jug filled.
I am always aware of what I have and trust me methanol is way different than gasoline.......Its usually clear and cold to the touch.
Gasoline is always vaporous and some fuels from VP are offensive to the nose....methanol is not and more like water....
The fuel issue for us all is a real Pain in the butt.....cost and availability.....
When I can I buy drums and have my own fuel....
Sunoco has a lesser rep for using clean drums.....and that is probably the only issue with their fuel....The only problem I've ever heard of about Sunoco is exactly that....contaminated drums. That's probably the fault of the dealer or distributer...
Buying fuel from pumps like at MG with tanks is also a chance for issues...but that is what we have to deal with.....Insinger supplies all the Sunoco in this area.....
If your worried about fuel quality issues than buy VP .....they have a better rep in that regard....
At the cost we pay for race gas, the suppliers should be handling the fuel and storing it properly.....
Rich Biebel
S/C 1479
Stock 147R
Old 10-28-2018, 02:52 PM   #39
HR9121
HR9121's Avatar
Granted I haven't been doing this as long as alot of you but I have never failed fuel check with VP or Sunoco. Alot of it has to do with how the fuel is handled, jugs clean, fuel system cleaned out and flushed when changing fuels etc. Maybe I'm just lucky!
James Williamson
W200 J/SA. SS/JA
Old 10-28-2018, 10:04 PM   #40
1320racer
1320racer's Avatar
please elaborate about the problems you witnessed as a result of Sunoco fuels...Standard aka Purple, Supreme aka Blue and Maximal aka red, those that are in use in bracket cars, stock, super stock, throttle stop classes, Top Sportsman, Top Dragster.
You can count me amongst them, having bracket raced for 27 years and used every oil, plug, converter, carb, manifold, tire, yada, yada, yada as well VP fuels which I found offered no performance gain, no added consistency, only added cost.
Many bracket and class racers all across the country use Sunoco fuels, some for decades as I have and I don't personally know one that has had any issues with Sunoco fuels on the dyno or the track.
Make sure you check it before you dump it in your fuel cell..
Agree with all the above.
I like Sunoco and have had good results with it. I'll continue to buy it and run it.
Now lets get back to the reason for this thread, the OP's whining and complaining because nobody at his local sunoco distributor will talk to him after he poured alcohol into his fuel cell.
