Old 01-09-2017, 09:50 PM   #61
Dennis P Chapman
Liked 53 Times in 25 Posts
Default Re: The best "Dime Rocket" combos!
I've been tinkering with one of these. Completely stock except for a cold thermostat, short, sticky DOT tires and blue sunoco it's gone 14.50s at "The Beav". Probably go 14 teens at Cecil. So far, it's been pretty consistent too. I don't know what it weighs but it's probably somewhere between A and B weight.
A couple of years ago, I watched some "kid" drive one in at "The Beav", took out his drivers-side headlight assy., put sticky DOTs on it and plugged his laptop into it. 12.70s! Blew me away! He told me that he changed the drive chain and gears, put in a converter out of a 3.4 Monte Carlo and stock LT-1 injectors. I don't know how he reprogrammed it but he DID say that he didn't mess with the boost because he "has to drive it home".
Needless to say, I was impressed.
nice
Dennis P Chapman 1904 STK
Old 01-10-2017, 02:09 AM   #62
Mike Meier
Liked 39 Times in 8 Posts
There was a Sam Tech student running a '00 Grand Prix in BF/S at the Dallas Divisional last April. If I recall correctly he said that he hadn't even had the valve covers off but he had tuned it with the lap top and a few other minor things. He ran in the low 14's but was a DQ.
Billy, have you looked into the aftermarket goodies for the 3.8? I am assuming you'd go the do-it-yourself route on the headers, but there are a few items out there such as the poly mounts, shortened dog bones, and custom flashed PCMs.
Mike Meier
"World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough
Mike Meier is offline   Reply With Quote
Old 01-11-2017, 01:27 AM   #63
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Well here is a starting point for the GM guys ....
http://www.ebay.com/itm/1978-1987-GM...3D361834523654
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 01-11-2017, 09:00 AM   #64
Billy Nees
Liked 7,782 Times in 1,743 Posts
Well, that would definitely be a frame up!
Billy Nees 1188 STK, SS
Old 01-11-2017, 07:47 PM   #65
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Originally Posted by Daran Summerton View Post
Bought a 2 bolt cast crank 350 for $200. Bought a nice set of pistons and rings for $89, stocker cam, still have press studs and stock pushrods and rockers, moroso valve covers and a Qjet I found in the back of a pickup truck. Pretty much it.
When I blow it up I'll probably just get a new 4 bolt GM Jegs engine for 1499$ and put a solid lifter cam in and change the heads. Shift that sumbitch at 7200
It's always the cheapest tossed together crap that surprises ya!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-24-2018, 12:12 PM   #66
Billy Nees
Soooo........., I'm guessing that being the Holidays and all, now is a good time to wake up the "Dime Rocket" threads and see if anyone has anything new to add in the way of cheap?
And that being said, I should give a "tip-of-the-hat" to all of those Div.6 "Dime Rocketeers"!
Old 12-24-2018, 05:59 PM   #67
john ancona
john ancona's Avatar
Liked 186 Times in 57 Posts
Best (low cost) engine combo for a 1977 Nova
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 12-24-2018, 07:16 PM   #68
dondon
Liked 10 Times in 5 Posts
I know it's a little old (not much available} but what does everybody think of something like a 221 or 260 2 bbl 62-63 fairlanes, even a 260 64 falcon. That was always my pipe dream dime rocket.
dondon is offline   Reply With Quote
Old 12-24-2018, 07:31 PM   #69
Easy Money,
C'mon now .You know the answer... 302 2bbl ..It's only a name on a spray can of engine enamel
Old 12-24-2018, 07:36 PM   #70
HP too high.
Wouldn't you rather have a 302, bigger cam, bigger carb, same compression, LESS horsepower? I know I would.
