#71 |
Liked 719 Times in 220 Posts
I guess a few persons wanted to check out the specs on the 409- the original cam in a '62 380 or 409 horse engine ended in part #930, it had .439" lift on both valves.It was a carryover from the small port '61 360 horse 409. A running change was the 3830690 cam, it had .507 intake lift, .519 exhaust lift. NHRA let you use it without any horsepower penalty. The '63 engine used the same cam, but it didn't seem to get a horsepower break, the engine was rated at 400 horsepower or 425 horsepower. The only difference between the '62 hi po 409 and the '63 was the chrome valve covers, air cleaner, and dipstick,and the '63 cast iron exhaust manifolds were a cast iron header that did work better than the 2 1/2" outlet rams horns on the '62 motor, but you wouldn't use either one on a race car. The '62 engine and car is the one to build.The two engines allow the OEM head, the #690 casting, with the #583 head as a legal replacement. The 583 came on the '64 400 and 425 horse engine and the '65 400 horse engine. Only difference was that the valve spring seats were deepened and taller valve springs were used on that head to eliminate coil bind and to enhance spring life. They are more rare than the 690 heads. Have fun rounding up all these parts, and building these engines!! Oh,yes, the dual 4 barrel intakes are the same for all years.
#72 | |
Liked 684 Times in 289 Posts
MJ |
#73 | |
Liked 43 Times in 10 Posts
#74 |
#75 | |
You could ask Denny Ford or Aubrey Bruneau about the Chevys. I don't see where they would be a big problem in today's Stock Eliminator world.
#76 |
Mark,
Do you remember Don Scinto`s Pontiac wagon? I only heard stories. Ran Super Stock, because you could change the small cam out of the low HP 389? Perhaps you could elaborate MJ |
#77 | |
Liked 184 Times in 113 Posts
1958 to 1964 were the X bodies. 1965 to 1976 got the larger H-Body 1977 to 1996 GM stayed with the 1964 GTO/Chevelle chassis design. Malibu's became Impala/Caprice//Bonneville/Roadmaster/Caddy/Olds The Wagons had the Boxed Frames. Police Packages got the all the Chassis attach points bolted. |
#78 |
Liked 254 Times in 78 Posts
1970 Chevrolet Sta Wag 3S Kingswood Estate w/TH with 390 HP 454 Cu In Engine at 4943 lbs for H/SA.
1971 Chevrolet Sta Wag 3S Kingswood Estate w/TH with 365 HP 454 Cu In Engine at 5280 lbs for M/SA.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 01-08-2019 at 11:03 PM. |
#79 |
Don`t recall what it had to weigh in at, but 15-20 years ago, Jeff Davidson raced a early 70s Olsmobile Vista Cruiser station wagon here in Div.6, in SS/MA. To run that low of a class designation with a 455 cube engine , she had to be rather porky!
#80 |
Liked 7,811 Times in 1,748 Posts
another one for shelter-in-place discussion!
