Old 01-19-2019, 12:26 PM   #11
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Default Re: Penn vs Valvoline test results..Ed Wright
Dave Layer and myself were dyno'ing one afternoon over at his shop. I don't know how we missed it, but we made a complete 7800 rpm pull after the oil pump pic-up broke off on the previous pull. Embarrassing for both of us,. I don't know what we were looking at, but obviously not what we were supposed to be. The printout let us know we only had 5 lbs. of pressure the entire pull. We pulled all the caps, and the bearings looked like they had never been ran. Pretty unbelievable. The oil was Amsoil 10-30 Racing.
Jeff Niceswanger 3740 SS
Old 01-19-2019, 01:36 PM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Did that improve the power at all ?
Old 01-19-2019, 03:42 PM   #13
Jeff Stout
Liked 704 Times in 281 Posts
Curious x2
Old 01-19-2019, 04:23 PM   #14
Jeff Niceswanger
I looked up the sheets. Five horsepower. The pick-up broke on pull # 3 and the no oil pressure was pull was # 4. The short block had been broke in previously with a different set of heads. So oil temp might have been a little of that five horsepower. Dave's dyno did not register oil temp. Experienced dyno operators on here will know better than me
Man we sure do miss that guy ………..
Old 01-19-2019, 08:16 PM   #15
MR DERBY CITY
Liked 7,944 Times in 1,521 Posts
A very well respected engine builder told me that on one occasion the customer told him to drain all the oil out of the SBC engine before the last pull, it picked up 8 HP and was still in one piece when disassembled for a freshen up......I won’t reveal his name but he was the mayor of a small city between Texas and Arkansas.....
..LOL. ,!!!
Old 01-19-2019, 08:41 PM   #16
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by Ron Gusack View Post
I don't like all the moly in it and it's the main reason I got away from VR1 back in the 80's. Tear downs always had a bunch of black slime in the pan and I hated it.
Pull the pan when the engine is still hot/warm and you won't see that. High zinc oils (over 1,000 ppm) will precipitate additives when the oil is cold. -Al
"That'll never work....."
Old 01-19-2019, 08:49 PM   #17
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
So 5-8 hp from 10w30 to no oil ! Is it really worth any hp, from 10w30 to 0w5 LOL .we all do it ,but.......
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 01-19-2019, 08:57 PM   #18
ss3011
ss3011's Avatar
Oil helps the rings seal , without any maybe you would lose power from that and offset the gains from low oil pressure .
Old 01-19-2019, 10:35 PM   #19
Greg Barsamian
Liked 427 Times in 97 Posts
Looking for Opinions / Experiences on the differences between using Valvoline VR 10w-30 Synthetic-Blend vs Valvoline VR 10w-30 "Full Synthetic" motor oil?
Specifically with respect to ring wear?
Greg Barsamian is online now   Reply With Quote
Old 01-20-2019, 12:03 PM   #20
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
This might be true Alan, but I don't see the same amount in the pan after switching to Brad Penn, which has no moly. If I convince myself that the VR1 has better wear numbers, I'll gladly live with some goop in the pan.
The question that I can't seem to get a decent answer to is why so many racers use multi weight oil instead of straight weight.
Ron Gusack is offline   Reply With Quote
