Old 01-28-2019, 05:02 PM   #21
Rob Fisher
Default Re: Attn. 265 Racers.What block is the best?
Hi Lyn.....I have for sale parts from a 1955-56 Chevy 265 4bbl engine...
Intake # 3837109 J105 date........50.00
265 std block # 3720991..............50.00
Heads # 3703523 dated J204 and J264 50.00
std Crank # 6265 ...............................50.00
Distributor # 1110847..........................50.00
Manual trans flywheel 3703870..........25.00
timing cover w/ original flat head screws...25.00
Original water neck housing 370501B.....25.00
Fuel pump plate ,rod and factory marked bolts 25.00
Call or text 217-254-3115 ... Located in Humboldt IL 61931
WILL SHIP SMALLER ITEMS AND TAKE PAYPAL
Rob Fisher is offline   Reply With Quote
Old 02-14-2019, 09:37 PM   #22
Frank Castros
Liked 2,768 Times in 980 Posts
Lyn,
How much faster do you think the bogus but legal Turbo 400 or 350 is than the Powerglide?
Old 02-14-2019, 11:58 PM   #23
Lyn Smith
Liked 1,002 Times in 203 Posts
Red face Re: Attn. 265 Racers.What block is the best?
I really don't know Frank.Will do some back to back tests this spring.
Lyn Smith is online now   Reply With Quote
Old 02-16-2019, 06:50 PM   #24
56sedandelivery
A 57 265 block will also have a pad for a block mounted starter motor that the 55-56 blocks don't/can't have; makes it a lot easier to bolt up a 3 speed automatic, and not have to use an adapter. Plus they have better oiling than the 55-56 blocks. Getting hard to find, and I have one I'm keeping. There is also a rope seal conversion kit to a neoprene seal, Best Gasket Seal #3711X. I am Butch/56sedandelivery.
56sedandelivery is offline   Reply With Quote
Old 02-19-2019, 09:12 PM   #25
Frank Castros
Butch,
What is the part number for those blocks?
Old 02-20-2019, 04:24 PM   #26
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Butch,
#3731548. Same number as the '57-283. Will have a "C","CD" or "CE" on the front pad.
55 Chevy is offline   Reply With Quote
