Old 01-31-2019, 08:14 PM   #11
Frank Castros
Liked 2,626 Times in 950 Posts
Default Re: Adjustable PCV Valve
Interesting subject, I hope more with contribute to this thread.
Old 01-31-2019, 10:56 PM   #12
Ed Wright
Ed Wright's Avatar
Originally Posted by Hacksaw View Post
OK, we are talking a drag race engine here so why would you want to let crankcase pressure fumes enter the intake side and taint the fresh fuel charge?
It's air.
Ed Wright 4156 SS/JA
Old 02-01-2019, 08:23 AM   #13
Billy Nees
Liked 7,682 Times in 1,730 Posts
It's air.
^^^^^^^^^^^^^^^^^^^^^^BINGO^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^
Especially in a severely restricted engine.
Billy Nees 1188 STK, SS
Old 02-01-2019, 11:39 AM   #14
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by Dragsinger View Post
The tech sheets show the valve works with an idle vacuum above 7" Most of our stockers or super stockers do not have 7" vacuum idle.
Who says it has to work? (Or work as the emissions system was designed?;-)
Remember those NASCAR and other intakes with the drilled out mounting studs? This is a lot bigger hole.
Old 02-01-2019, 12:41 PM   #15
Ed Wright
Ed Wright's Avatar
[QUOTE=Bobby DiDomenico;581432]Who says it has to work? (Or work as the emissions system was designed?;-)
Yeah, and nobody ever clipped a spring, with a restricted engine that, naturally, pulls manifold vacuum @ WOT, right?
Old 02-01-2019, 02:49 PM   #16
Coleydog
Liked 53 Times in 38 Posts
Just like another throttle blade, kinda bad mixture at idle but wide open a good increase, just richen up the jets. Big breather on other valve cover, not much oil spray. Would be interesting to see what cfm goes thru it. I can see why tech would shoot it down.
Old 02-01-2019, 05:17 PM   #17
Ed Wright
Ed Wright's Avatar
I have heard of guys using epoxy & a drill to convert the PCV hose nipple from manifold vacuum, to "ported" vacuum, which only pulls air with the throttle blades open. Just heard stories about that. Don't really know.
Old 02-01-2019, 08:25 PM   #18
Timetraveler
Liked 12 Times in 6 Posts
I had one that rattled when I shook it. I thought it was broke "So I fixed it".
Timetraveler is offline   Reply With Quote
Old 02-01-2019, 08:39 PM   #19
Tom Meyer
Liked 351 Times in 120 Posts
There are guys running check valves from power brake units instead of the pcv valves. Its a poor mans vacuum pump. was always told if you could keep some vacuum in the crankcase say 3 in it would free up some power. Remember for all the air that is moving on top of the piston there is air moving below it also. Back in the day they said it helped ring flutter. But with todays ring combos who knows. Tom
Tom Meyer 5240 SS Stock ???
Old 02-02-2019, 10:39 AM   #20
Coleydog
Back in the 70s I used a hemi fuel pump hooked to a PCV on my max wedge 64 Plym (later valve covers) I did it mostly for blow by, had to use a catch can so it was doing something.
