Old 02-02-2019, 12:53 PM   #21
MR DERBY CITY
Liked 7,930 Times in 1,518 Posts
Default Re: Adjustable PCV Valve
Posting for a friend with a 2 barrel.......
He never tightens his carb bolts, and he has a hellacious throttle return spring, actually two of them....
MR DERBY CITY is online now   Reply With Quote
Old 02-02-2019, 03:27 PM   #22
Liked 5,120 Times in 1,951 Posts
Wasn't illegal until a bit after this picture was taken...
Old 02-02-2019, 05:13 PM   #23
GTOMayhem
Liked 22 Times in 14 Posts
^^^^^^^^^^^^^^^^^^^^^^BINGO^^^^^^^^^^^^^^^^^^^^^^^ ^^^^^^^^^^^
Especially in a severely restricted engine.
So on a small cube motor, say a 305, with a Quadrajet; no benefit from anymore air? Also asking for a friend.
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 02-02-2019, 06:05 PM   #24
Billy Nees
Liked 7,708 Times in 1,736 Posts
On my 301 4V I use a power brake check valve with the crankcase sealed. I like to TRY and keep some vacuum in it. I can't tell if it's worth anything but it doesn't seem to be hurting it.
Billy Nees 1188 STK, SS
Old 02-02-2019, 06:18 PM   #25
I don't think you can pull much vacuum in the crankcase with just a PCV ..Maybe with the check ball completely removed.. Would be hard to tune that set up ;-)
You need the header hoses for high speed suction. Of course, not legal in Stock.
I just use the PCV to help keep more of that thin synthetic oil inside the motor.
Old 02-02-2019, 06:50 PM   #26
GTOMayhem
So no breather on the cover? Just the brake check valve on one of the valve covers? Or being a Pontiac, the valley pan?
Rick Thomason
GTOMayhem
Old 02-02-2019, 07:42 PM   #27
Billy Nees
Yup.
