#21 |
Liked 7,940 Times in 1,520 Posts
Posting for a friend with a 2 barrel.......
He never tightens his carb bolts, and he has a hellacious throttle return spring, actually two of them.... |
#22 |
Liked 5,125 Times in 1,953 Posts
Wasn't illegal until a bit after this picture was taken...
#23 |
Liked 22 Times in 14 Posts
#24 |
Liked 7,761 Times in 1,741 Posts
On my 301 4V I use a power brake check valve with the crankcase sealed. I like to TRY and keep some vacuum in it. I can't tell if it's worth anything but it doesn't seem to be hurting it.
#25 |
I don't think you can pull much vacuum in the crankcase with just a PCV ..Maybe with the check ball completely removed.. Would be hard to tune that set up ;-)
You need the header hoses for high speed suction. Of course, not legal in Stock. I just use the PCV to help keep more of that thin synthetic oil inside the motor.
#26 | |
So no breather on the cover? Just the brake check valve on one of the valve covers? Or being a Pontiac, the valley pan? Rick Thomason GTOMayhem |
#27 |
Yup.
