Liked 11 Times in 5 Posts
I'm sure this has probably been beat to death previously. Has anyone ever done a back to back comparison on using a cool can versus not using one ? Does anyone even make one these days, as I know Moroso has stopped production. Thanks in advance
#2 | |
Liked 216 Times in 77 Posts
Canton still makes one but its a little pricey. Over $200 but it does look like a nice. |
Liked 20 Times in 15 Posts
Its cooler/denser air that makes the HP.
#4 | |
Liked 163 Times in 53 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
When I had my '56, I was an aircraft technician. I had our sheet metal shop make me a box, mounted next to the front of the radiator. Was about 6" x 12", (not round) with a -6 an fitting (with an -6 an cap)TIG welded on, drained water right through the factory radiator drain hole. Used aluminum tubing, transfers heat better, top flap/lid was on hinges, with aircraft latches to hold it shut. Testing with it bypassed, or full of ice, fuel lines sweating at the carbs, was a solid 8 hun quicker cold. At Fuel Check, near the scales, those old Carter WCFB float bowls would feel cold, and sweating.
People can repeat "only air temp matters", it's another thing Jere Stahl told me to do, and he was correct. I am not the only person having the same experience with that. I know a fast Pro Stock car that cools fuel before pouring it in the car, and icing the fuel cell. That was my experience. Right or wrong.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 02-16-2019 at 07:39 PM. Reason: Still can not type. Sorry. |
#7 | |
Liked 225 Times in 136 Posts
Ed you absolutely correct on this!
Banned
Liked 179 Times in 89 Posts
I guess this rule pretty much made cool cans obsolete.
General Regulations Section 21, page 5 Fuel/Air: Any method of artificially cooling or heating fuel prohibited (i.e., cool cans, Freon, wet rags, etc.), except as noted in Class Requirements. Cool cans, wet towels, etc. are permitted in Super Stock, Stock, Super Comp, Super Gas, Super Street, and E.T. classes. Wet towels, rags, ice, etc. must be removed before vehicle leaves staging area. Coolers, chillers, etc., where permitted by class requirements, are prohibited outside of the competitor’s pit. Ambient-temperature air only; cooling or otherwise changing the conditions of the intake air is prohibited. Spraying of intake with any artificial spray or coolant prohibited. |
#9 | |
Liked 22 Times in 14 Posts
Not obsolete, the way I read it. Rick Thomason GTOMayhem |
Banned
