#41 |
the chassis certs are @ 7.50 for current FSS cars, I wonder when they'll eclipse that ??
#42 |
Liked 128 Times in 50 Posts
That's even worse. I was basing my estimate off of buying the car, pulling the engine and trans to have them gone through.
Bobby Lundholm 3516 G/SA |
#43 | |
Liked 17 Times in 12 Posts
It already is !
Marty Hanft |
#44 | |
Liked 302 Times in 114 Posts
#45 | |
Liked 53 Times in 20 Posts
new car $130,000 Build a showdown engine $40,000 Showdown Trans and convertor $15000 Update cage to 7.50 spec $9000 full racepack $8000 second set wheel tires $3500 Lighten car add weight to back $500 different third member $2500 Proper shifter $1000 Suspension $10,000 in car communication $1500 Assorted other things needed $3000 Spare parts $$$$$$$ Total at least $225000 You can do it for a bit less but you will not qualify and may not even at that cost either. And constant work needed after each event. And add in a trailer and Motor home you can add $250,000-$400,000 It is not a class for the average sportsman. |
#46 |
Liked 684 Times in 289 Posts
JDM Engineering once posted on here, that one of his customers had 100K in the trans. I asked if he meant 10K, he said nope.
MJ |
#47 |
Seems high you can buy a Coan or Joel Showdown trans for 10-11 grand and a aluminum light weight bolt together converter for 5-6 grand Maybe he had it gold plated.
#48 |
Liked 184 Times in 113 Posts
Damn I wish Pure Stock was back.
Getting it set up to make STOCK is $10000. Another $10000 to make it competitive with other care in class And that is cheap. To really make it all up requires frame up restoration to benefit from all the rules. Weight shifting, special bearings, REM, metal treatment. ETC The concept of Stock left reality a long time ago. They are Comp cars with a smaller cam. |
#49 | |
Guest
Posts: n/a
This has what to do with Factory Showdown racing?
#50 | |
Liked 370 Times in 101 Posts
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
