Old 03-21-2019, 07:54 PM   #21
weedburner
Liked 20 Times in 16 Posts
Default Re: Radial tire question
Originally Posted by Jim Caughlin View Post
Mike, not bashing your product but have you checked with NHRA about the legality of this for Stock & SS? The reason I ask is that I proposed something similar to this quite some time ago and was told absolutely not. They said that anything that affected the release of the clutch linkage would not be legal. I think their issue is that this kinda gets into the delay box gray area. Jim
If that question was intended for me, I have no idea if it's NHRA legal for stock or SS. It does not affect the manual release of the pedal with your foot, it only stops the pedal's return at a pre-determined point. Basically the same as adjusting base pressure, except that it also has a bleed that allows additional pressure to then come in at a much slower rate. That allows more slip during launch without blowing thru the clutch in high gear.
Here's a Psi graph showing what it does on a hyd throwout bearing. The vertical drop of the trace was all foot controlled. It's only after the clutch hits that pressure drop is controlled (acts on the pedal itself, also compatible with mechanical linkage)...
There's an article in the April issue of NMCA/NMRA's Fastest Street Car Magazine. I have not seen it yet, but I hear they interviewed some racers that are using it.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 03-21-2019, 10:29 PM   #22
Tom Meyer
Liked 354 Times in 120 Posts
I always thought you could not run a hyd clutch in stock super stock. Tom
Tom Meyer 5240 SS Stock ???
Old 03-22-2019, 12:17 PM   #23
Ed Wright
Ed Wright's Avatar
Originally Posted by Mike Rietow View Post
Someone will bridge the gap. They always do. It's essential-intrinsic.
Been that way for years. Maybe they will.
Ed Wright 4156 SS/JA
Old 03-24-2019, 10:40 AM   #24
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
So, the bias slick's fundamental for traction is its deformation. > High energy losses at all frequencies. So, the bias slick is fundamentally inefficient.
The radial is the opposite, low energy loss at all frequencies. Traction at all frequencies if you can keep it from deforming. Efficient, less rolling resistance. Faster, quicker et's.
The fundamental for wheel speed we've found effective for radial tires is the same as limiting wheel stands. Prolong the period of time the shaft is neutral in, or even exiting the damper/shock main body. We run a two way rebound adjuster on a heavy 2950pd small tire radial nitrous leaf spring car to combat wheel stands. No wheely bars allowed in the class. It lays tracks 275 radial, one teen sixty foot. There's another idea, maybe smaller tire would be easier to manage, deformation. Dunno, be interesting to see who gets there first on a radial.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 03-25-2019, 03:20 AM   #25
Adger Smith
Liked 880 Times in 311 Posts
Mike.
We have been using wheel speed/slippage to go fast in Comp/Modified/Gas classes for 4 decades. At the time those were not bracket classes. We all know bracket guys want a dead Hook. A turn to a turn and a half after the hit on roll out usually produces the quickest ET. Watch this with no wheelie bars and a V-6. The tire slips gets it off the line. The engine stays up on the converter after the hit. Hard to dial.
We didn't have computers back in the early 70's and there was a lot of trial and error to make things work. Ed Wright knows what I'm talking about. He was there, too. Glad to see you guys working on this kind of stuff. That is getting the performance instead of being one of the dead hook crowd.
Adger Smith (Former SS)
Old 03-25-2019, 11:07 AM   #26
weedburner
Clutch hit control is what you need to make radials work with a stick.
I don't share competitive graphs, but this one had a few problems so I can show it here. It shows what a dead hook launch looks like using one of my clutch hit controllers. 302ci sealed crate engine running the spec tune, 3100lbs. Class doesn't allow radials, so this run is with a 10.5" bias slick @ 18psi...
First problem was not enough delay after the hit, which caused rpm to get pulled down to about 5200 after launch. 5500 is typical.
Second problem was the PP needed to be shimmed a little more in order to control those wheelspeed spikes after the shifts.
Depending on the track/conditions, it's not unusual for the above car to be able to go above 20psi with bias slicks and still dead hook without pulling rpm below 5500.
Grant
Old 03-25-2019, 09:40 PM   #27
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Radials can be made to work. All of J Allen Sherman stick customers use radials except for me. I just haven’t messed with them yet. Steve Kent uses them on his AH cud’s and his bad azz SS/B Vette. Stan Holt and Jarrod Grainer run radials on both super stocker and their stick shift comp car. Go to dragracertv and watch this pass weekend runs by Jarrod Grainer 66 Chevy II and watch how it leaves on those radials. It’s a thing of beauty.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-25-2019, 10:42 PM   #28
Mike Rietow
Good call. That's a bad dude. 1.38 on the back tire. Thanks for the tip. That's a clinic.
