Old 03-26-2019, 07:12 AM   #21
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Master Cutoff Switch
Coincidently, NHRARacer.com has a battery question this week. I never had or plan to have a car faster than 9.99 or 135 mph. but I never knew or even noticed that they apparently need a cut-off regardless of battery placement. External switch also?
http://www.nhraracer.com/content/gen...336&zoneid=132
LOCOMOTION Racing
Old 03-26-2019, 07:28 AM   #22
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
Default Re: Master Cutoff Switch
Originally Posted by J&S Racing View Post
I’ve decided to run a switch even though I don’t plan on putting a battery in the truck just yet.
My question is about the wire from the alternator, can it run to the battery or does it need to be run to the switch?
probably need a cutoff like this one
Old 03-26-2019, 08:02 AM   #23
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
Your alternator wire and battery cable should be on the same post on the switch. The other post on the switch will run the cable to your starter solenoid.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
Old 03-26-2019, 08:40 AM   #24
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Travis, I’m guilty of not having mine labeled. Thanks for the reminder, I will address it.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-26-2019, 12:06 PM   #25
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I had a double pole Moroso to kill the alternator until a short at the starter burned it out. I replaced it with a single pole rotary at half the price wired like this and it works fine. No engine run-on.
Dale Shearon
68 Mustang 6394
Old 03-26-2019, 02:25 PM   #26
CMcAllister
Liked 931 Times in 265 Posts
This is the simple legal way to do it without extra wiring, solenoids, etc. You just have to be mindful that the alternator lead is always hot, and pay attention to making sure it is protected where it is routed and when working on the car..
