Old 04-13-2019, 07:07 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: Heads up
Originally Posted by curtis reed View Post
Sorry for my ignorance but why is a restrictor plate illegal? I find it odd that something to slow you down is a problem.
Curtis
They are concerned with their AHFS (Automatic HP Factoring System) deal to even the combos out by adding HP to the faster car, causing them to carry more weight (eleven lbs per hp for my class) to slow them down. Too much like bracket racing now.
I slow it down in the computer. Nothing for anybody to see.
I also got chewed out for clicking it off at 1000 feet once during qualifying. I don't do that anymore, either.
Ed Wright 4156 SS/JA
Old 04-15-2019, 08:47 AM   #22
curtis reed
Liked 125 Times in 59 Posts
Slow it down in the computer. Nothing for anybody to see.
Gotcha. Thanks.
curtis reed is offline   Reply With Quote
Old 04-16-2019, 11:43 PM   #23
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Originally Posted by jmoneyfoot View Post
So everyone holds back a little?
No.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 04-18-2019, 10:15 AM   #24
Ed Wright
Ed Wright's Avatar
Originally Posted by Darrel Goheen View Post
No.
With this live timing, other guys running the same engine often watch you.
Last year, first pass at No Problem, mine stood up & hit the wheelie bars hard enough to unload the tires, which causes the RPM to spike, causing my computer to shift it to second while up in the air, I was in second gear by 60'. I had new heads, and needed to see my air/fuel data log in high gear, where RPMs climb slower. I thought "this run is crap, I'll run it out the back for that.
Got my time slip, 9.87. Thought "I'm going to hear about this one!". My phone beeped while sitting on the scales. Back at my pit spot, got out of the car, dug my phone out, found a text: "What the f**k are you doing?!" From another LT1 racer. If I thought it would be that fast, after the bad launch, I would not have run it out.
Yes, some guys hold back.
