#21 |
There ya go!
Ed Wright 4156 SS/JA |
#22 | |
Liked 320 Times in 102 Posts
#23 |
Liked 133 Times in 76 Posts
I'm a believer in magnets too. I use neodymium high heat magnets everywhere. i use epoxy to glue them to my aluminium trans pan. I stick a couple on the bottom of the oil filter. I have some in the oil pan and in the cylinder heads. You would be amazed at the coating of metallic fuzz that is accumulated. When I adjust valves I clean the magnets and they always have a coating and when I cut the oil filter you can see the rings of the magnet on the bottom of the can where it picked up metallic particles.
#24 |
Liked 10 Times in 6 Posts
The magnets sound like a good idea,I will get some. I see Home Depot sells Rare Earth magnets.Will those work? Thanks for the good info.
#26 |
Liked 544 Times in 213 Posts
Wix 51061 =
Napa 1061 Every wix filter uses the same number as Napa but drops the first number. The first number in Wix filters denotes what it is for. 3 series = fuel 4 series = air 5 series = oil We buy thousands of filters a year and use Wix in our generator service business. From the biggest to the smallest machines. When we are out and need one we just get one from Napa I’ve been using the Wix racing filters for years. The only feature that would be good on some applications is the nut on the bottom that K&N and Moroso features. My oil pan makes it a struggle to get a strap wrench on a std round filter. I modified a strap wrench....
#27 |
I have a NAPA Oil Filter socket. Grips the "notches" around the end of the filters.
Has a square hole for a 3/8" drive Rachet or extension, takes them right off.
#28 |
Liked 184 Times in 113 Posts
Wix has two filters.
One for racing another for street! |
#29 |
Liked 920 Times in 259 Posts
FilterMAG is the brand name of a line of oil filter magnets sold at the mail orders and other places. Magnets are very strong and they work well. Probably a good idea especially if you are using a larger micron rated filter.
No love for the System 1 type filters or the Clear View see through mounts? |
#30 | |
I have them at work but not at home....
