Looking for some old Ford 3ring superstock pistons. .4.040-4.060 stock pin 302 Ford
, brand doesn't matter. Trying to build garndkids a little bracket motor. Thanks Much, Larry Ingram |
Liked 4,388 Times in 504 Posts
Have a set of 2 ring 4.060 pistons BRC super stock 289.
Bobby, Thanks for the for the response, just in case I don't find the others, what top ring and how much.
Larry, I found a set of Ross 4.060 2valve flat top pistons I used in the past. They weigh 370 bare. Have 912 pins with them. Top ring is dykes and think it is a 4mm oil ring. I also have BRC set. They are also 2ring with side gas ports. Valve reliefs are cut wider and deeper though. They weigh 400 grams bare and have 927 pins. 300.00 per set with pins obo
Also have some camshafts, con rods (ford), stock victor jr manifold, distributors, etc. Thanks Bob |
