#11 | |
Liked 7,732 Times in 1,739 Posts
It might help you to look up my old "Under the Index for Under a Grand" thread. I posted some pics on there of how I took off the booster and modified the pedal.
#12 |
Liked 5,121 Times in 1,952 Posts
The factory power eliminator aluminum piece raised it up some, too. Very rare!
#13 |
Liked 118 Times in 41 Posts
Thanks Mark and Billy. I never thought to raise the master cylinder. I can do that. Would making the pedal 2 inch longer do the same thing? More leverage.
U/SA 79 Mustang |
#14 |
Liked 1,104 Times in 302 Posts
The best bet would be if you could find a complete manual brake setup from a low option early FOX Mustang, Fairmont etc. That way you get the correct manual brake pedal, the aluminum master cylinder firewall mounting bracket, and master cylinder. As Mike Graham mentioned, the manual brake pedal pedal location on the pedal bracket is also different, but both holes are drilled, so simple to move the pedal pivot location. Not sure what the caliper bore size on your larger front disc brakes are, but that could potentially be a problem. My 85 Mustang started life as a 4 cylinder car, and I retained the small factory front disc brakes, and stock rear brakes from the 5.0 doner Mustang, and swapped all the factory manual brake pedal, master , and bracket from a stripper junkyard Mustang. Had no problems stopping the car from 107 MPH, and even with the much stronger bracket engine, going 128 MPH, the stock, small brakes worked pretty good.
#15 | |
Liked 240 Times in 112 Posts
My car has 2 stubs welded on the brake pedal lever from the factory. I also put as large of a Rear wheel cylinder I could find on the Fronts. (4 wheel drums)
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 05-12-2019 at 12:54 AM. |
#16 | |
It creaked and groaned and smoked , but it went, on a good size drill press . Kinda like drilling a center bolt into mono leaf springs..Ahnold probably could have done it a little easier.
#17 | |
Liked 799 Times in 236 Posts
"That'll never work....." |
#18 |
Liked 44 Times in 15 Posts
Here's an adapter for the master cylinder. https://www.ebay.com/itm/Pro-5-0-79-...wAAOSw7cZcM86v
#19 |
Liked 223 Times in 73 Posts
For what it's worth I changed the pedal ratio and wound up never installing the proportioning valve that I bought. If anything the pedal is a little soft, but I can get over 1000 PSI easily in one shot and it holds fine on the line (as long as the 2-step in on...).
It took a could of tries to find the right bore size for the master cylinder but it was worth taking the time to work it out. I wound up with 1 1/8 inch. |
#20 | |
I'm sure the pedal arm is hardened for safety reasons.
