Old 05-12-2019, 11:48 AM   #21
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: Brakes help
If your doing any mods to the MC make sure the pushrod is secure so it don't fall out from the back of the master. gsa612
Old 05-12-2019, 01:00 PM   #22
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Originally Posted by jerry witzel View Post
Here's an adapter for the master cylinder. https://www.ebay.com/itm/Pro-5-0-79-...wAAOSw7cZcM86v
I have one of these already
U/SA
79 Mustang
Old 05-12-2019, 01:03 PM   #23
RobbieRacer
Originally Posted by Dave Noll View Post
Umm, If it is actually Case Hardened, A solid carbide drill bit is not going through it. I like the welding in an extra 2", that will give more leverage but will put the pedal close to the floor.
My car has 2 stubs welded on the brake pedal lever from the factory. I also put as large of a Rear wheel cylinder I could find on the Fronts. (4 wheel drums)
Mine only has one stub and it's also welded on.
U/SA
79 Mustang
Old 05-12-2019, 03:02 PM   #24
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Makes sense. Might be then. Once you get the drill bit started, it'll go.
I'm sure the pedal arm is hardened for safety reasons.
Case hardening only hardens the surface. The material under the hardened surface remains unaltered. -Al
Machining through a 60Rc surface can be done, but not easily at all.
Speeds and Feeds
SFM IPM DOC (Inch Depth of Cut)
Carbon And Alloy
Steels (50-60 Rc) 300-500 0.002-0.008 0.003-0.020
Die Steels (55-65 Rc) 150-350 0.002-0.008 0.003-0.008
Dave Noll, EF/S ,?/SA 6526
