Old 05-23-2019, 08:52 AM   #11
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default Re: Air Bag?
I think i and going to try air bags on both sides running more pressure on the right side. Cheap fix at under $100,
I noticed in the video that the T-bird did not drop in the rear at all. Doesn't a T-bird use the same set up as a mustang in the rear?
U/SA
79 Mustang
Old 05-23-2019, 05:22 PM   #12
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
Same as a T-bird 78 to 88 I believe. My car didn’t squat much until I softened the compression on the shocks.
Shadylane is offline   Reply With Quote
Old 05-23-2019, 09:50 PM   #13
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Has anyone tried these ?
Name:	Screenshot_2019-05-23 Team Z stock location rear springs 1979-1993.png
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 05-23-2019, 11:54 PM   #14
Shadylane
Shadylane's Avatar
I have never observed the wheel changing speed up and down on the launch like it did in the right hand slow mo. Was it to much psi or not enough?
Been experimenting with tire psi. Dead hooking kills the clutch so I had the tire up to 30. Didn’t get the tires clean on that run.
Always something!
Old 05-24-2019, 07:13 AM   #15
nhramnl
Liked 358 Times in 83 Posts
Back when dinosaurs roamed the earth, guys who raced coil spring rear suspension cars (I'm thinking about 60s Chevelles) just installed an Air Lift airbag in the right side spring, inflated it to the minimum psi required to kill the roll rotation and all was right with the world. Worked like a charm, was way cheap and didn't have any real effect on anything but the problem.
Old 05-25-2019, 12:28 AM   #16
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
In my 1969 Impala Stocker.
Used Airbags and glued a piece of 2by4 on axle housing.
On launch it hit the pinion snubber.
