Old 04-26-2019, 07:05 AM   #21
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
Default Re: Super Street Help
FYI that the Willys plate is even available on eBay.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-26-2019, 08:49 AM   #22
scamper
Have you used that plate,Willys,by chance just not sure how you would get it set up after you moved it I don't see any measuring other wise seems the same as et genie any input on any of these systems would be great
scamper is offline   Reply With Quote
Old 04-26-2019, 09:59 AM   #23
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
EZ is out of business and I've been using the Willy's adjustable restrictor plate since 2007 and nothing else could be easier. Adjustments take all of a few seconds and are linear with each turn worth .04 on my combo. There are 18 turns of which the first 2 have little effect. I have one for sale if you are interested.
Old 04-26-2019, 11:12 AM   #24
scamper
How much where you killing with the plate,did you need to make carb adjustments due to the reduced signal of the restriction.On the off topic how do these seal up for vacuum leaks and also keeping tention on the adjustment so it does not move on you does that wear out at some point.
Might be intrested in that plate what are you looking to get for it.
Thanks
Old 04-26-2019, 12:36 PM   #25
1320racer
1320racer's Avatar
Killed between 50-100HP depending on weather and elevation. used to slow the car to 9.0x from a best of 8.70. No adjustments to carb, no vacuum leaks and a seasonal drop of lock tite red keeps the adjuster from loosing on a pass.
They sell for about $350, make me an offer via PM.
Old 06-07-2019, 06:45 PM   #26
scamper
Smile Re: Super Street Help
Just a follow up,made it to my 1st event with NESSA this past weekend.No plate so had to find a bail spot 1st tt was a fail 11.67 but .009 on my 1st pro tree.Got closer on the 2nd tt 10.88 and ended up making it to the semis for the day when I failed to compensate my spot for the worse air but good fun all around
